Hi. MPICH has some pretty nice functionality for memory pools implemented, but as far as I can tell, it’s a bit limited for internal device use because each pool you implement needs to consume an entry in the handle space. Looking at the available “kinds” of memory pools already implemented: typedef enum MPID_Object_kind { MPID_COMM = 0x1, MPID_GROUP = 0x2, MPID_DATATYPE = 0x3, MPID_FILE = 0x4, /* only used obliquely inside MPID_Errhandler objs */ MPID_ERRHANDLER = 0x5, MPID_OP = 0x6, MPID_INFO = 0x7, MPID_WIN = 0x8, MPID_KEYVAL = 0x9, MPID_ATTR = 0xa, MPID_REQUEST = 0xb, MPID_PROCGROUP = 0xc, /* These are internal device objects */ MPID_VCONN = 0xd, MPID_GREQ_CLASS = 0xf } MPID_Object_kind; It looks like only 0xe is available for implementing a new type of memory pool, limiting me to one additional pool. Furthermore, the internal device objects don’t need publishable handles, right? It looks like the handle contains 2 bits for (internal, valid, invalid, direct), and 4 bits to contain the object kind. Are there any memory pool routines that I’m missing somewhere that aren’t restricted to the limits of what we can publish in a handle? Since my object pools are internal, I don’t need to encode anything into a handle. Furthermore, if we had a set of non-handle pool routines, internal pools like procgroup, vconn, wouldn’t consume entries in the handle space that could be used for future versions of MPI. Looking for some guidance here, I don’t want to publish any internal device gorp into the object_kind space…but I want to use memory pools. I’ve used the mpich pools on internal objects with a garbage kind value (unintentionally set to the wrong enum value), and it appears I get a new pool and everything is working, but just because it works, doesn’t mean it’s correct. What should I do? Bracing for "implement your own memory pools, lazy”.
participants (1)
Archer, Charles J
