Re: [mpich-devel] ROMIO collective i/o memory use
sorry, haven't updated the PMR but it failed. Memory failure in PAMI. I will update the PMR today with the new results. kevin On May 6, 2013, at 1:41 PM, Bob Cernohous <[email protected]> wrote:
I agree and suggested: --------------------- It appears they don't have enough memory for an alltoallv exchange. Try '1'...
* - BGMPIO_COMM - Define how data is exchanged on collective * reads and writes. Possible values: * - 0 - Use MPI_Alltoallv. * - 1 - Use MPI_Isend/MPI_Irecv. * - Default is 0. ---------------------
but they didn't want a work around they wanted a 'fix for o(p) allocations'. There are o(p) allocations all over collective i/o from a quick glance. Just wanted some input from the experts about scaling romio. I haven't heard if the suggestion worked.
Bob Cernohous: (T/L 553) 507-253-6093
[email protected] IBM Rochester, Building 030-2(C335), Department 61L 3605 Hwy 52 North, Rochester, MN 55901-7829
Chaos reigns within. Reflect, repent, and reboot. Order shall return.
[email protected] wrote on 05/04/2013 09:43:10 PM:
From: "Rob Latham" <[email protected]> To: [email protected], Cc: [email protected] Date: 05/04/2013 09:48 PM Subject: Re: [mpich-devel] ROMIO collective i/o memory use Sent by: [email protected]
On Mon, Apr 29, 2013 at 10:28:01AM -0500, Bob Cernohous wrote:
A customer (Argonne ;) is complaining about O(p) allocations in collective i/o. A collective read is failing at larger scale.
Any thoughts or comments or advice? There appears to be lots of O(p) in ROMIO collective I/O. Plus a lot of (possibly large) aggregated data buffers. A quick search shows
The O(p) allocations are a concern, sure. For two-phase, though, the real problem lies in ADIOI_R_Exchange_data_alltoallv and ADIOI_W_Exchange_data_alltoallv . The O(p) allocations are the least of our worries!
around line 1063 of ad_bg_rdcoll.c
all_recv_buf = (char *) ADIOI_Malloc( rtail );
all_send_buf = (char *) ADIOI_Malloc( stail );
(rtail and stail are the sum of the receive and send arrays)
==rob
The common ROMIO read collective code:
Find all "ADIOI_Malloc", Match case, Regular expression (UNIX)
File Z:\bgq\comm\lib\dev\mpich2\src\mpi\romio\adio\common\ad_read_coll.c
124 38: st_offsets = (ADIO_Offset *) ADIOI_Malloc(nprocs*sizeof(ADIO_Offset));
125 39: end_offsets = (ADIO_Offset *) ADIOI_Malloc(nprocs*sizeof(ADIO_Offset));
317 44: *offset_list_ptr = (ADIO_Offset *) ADIOI_Malloc(2*sizeof(ADIO_Offset));
318 41: *len_list_ptr = (ADIO_Offset *) ADIOI_Malloc(2*sizeof(ADIO_Offset));
334 44: *offset_list_ptr = (ADIO_Offset *) ADIOI_Malloc(2*sizeof(ADIO_Offset));
335 41: *len_list_ptr = (ADIO_Offset *) ADIOI_Malloc(2*sizeof(ADIO_Offset));
436 18: ADIOI_Malloc((contig_access_count+1)*sizeof(ADIO_Offset));
437 41: *len_list_ptr = (ADIO_Offset *) ADIOI_Malloc((contig_access_count+1)*sizeof(ADIO_Offset));
573 37: if (ntimes) read_buf = (char *) ADIOI_Malloc(coll_bufsize);
578 21: count = (int *) ADIOI_Malloc(nprocs * sizeof(int));
587 25: send_size = (int *) ADIOI_Malloc(nprocs * sizeof(int));
590 25: recv_size = (int *) ADIOI_Malloc(nprocs * sizeof(int));
598 25: start_pos = (int *) ADIOI_Malloc(nprocs*sizeof(int));
739 32: tmp_buf = (char *) ADIOI_Malloc(for_next_iter);
744 33: read_buf = (char *) ADIOI_Malloc(for_next_iter+coll_bufsize);
805 9: ADIOI_Malloc((nprocs_send+nprocs_recv+1)*sizeof(MPI_Request));
827 30: recv_buf = (char **) ADIOI_Malloc(nprocs * sizeof(char*));
830 44: (char *) ADIOI_Malloc(recv_size[i]);
870 31: statuses = (MPI_Status *) ADIOI_Malloc((nprocs_send+nprocs_recv+1) * \
988 35: curr_from_proc = (unsigned *) ADIOI_Malloc(nprocs * sizeof(unsigned));
989 35: done_from_proc = (unsigned *) ADIOI_Malloc(nprocs * sizeof(unsigned));
990 35: recv_buf_idx = (unsigned *) ADIOI_Malloc(nprocs * sizeof(unsigned));
Total found: 22
Our BG version of read collective:
File Z:\bgq\comm\lib\dev\mpich2\src\mpi\romio\adio\ad_bg\ad_bg_rdcoll.c
179 40: st_offsets = (ADIO_Offset *) ADIOI_Malloc(nprocs*sizeof(ADIO_Offset));
180 40: end_offsets = (ADIO_Offset *) ADIOI_Malloc(nprocs*sizeof(ADIO_Offset));
183 43: bg_offsets0 = (ADIO_Offset *) ADIOI_Malloc(2*nprocs*sizeof(ADIO_Offset));
184 43: bg_offsets = (ADIO_Offset *) ADIOI_Malloc(2*nprocs*sizeof(ADIO_Offset));
475 37: if (ntimes) read_buf = (char *) ADIOI_Malloc(coll_bufsize);
480 21: count = (int *) ADIOI_Malloc(nprocs * sizeof(int));
489 25: send_size = (int *) ADIOI_Malloc(nprocs * sizeof(int));
492 25: recv_size = (int *) ADIOI_Malloc(nprocs * sizeof(int));
500 25: start_pos = (int *) ADIOI_Malloc(nprocs*sizeof(int));
676 32: tmp_buf = (char *) ADIOI_Malloc(for_next_iter);
681 33: read_buf = (char *) ADIOI_Malloc(for_next_iter+coll_bufsize);
761 9: ADIOI_Malloc((nprocs_send+nprocs_recv+1)*sizeof(MPI_Request));
783 30: recv_buf = (char **) ADIOI_Malloc(nprocs * sizeof(char*));
786 44: (char *) ADIOI_Malloc(recv_size[i]);
826 31: statuses = (MPI_Status *) ADIOI_Malloc((nprocs_send+nprocs_recv+1) * \
944 35: curr_from_proc = (unsigned *) ADIOI_Malloc(nprocs * sizeof(unsigned));
945 35: done_from_proc = (unsigned *) ADIOI_Malloc(nprocs * sizeof(unsigned));
946 35: recv_buf_idx = (unsigned *) ADIOI_Malloc(nprocs * sizeof(unsigned));
1058 23: rdispls = (int *) ADIOI_Malloc( nprocs * sizeof(int) );
1063 29: all_recv_buf = (char *) ADIOI_Malloc( rtail );
1064 26: recv_buf = (char **) ADIOI_Malloc(nprocs * sizeof(char *));
1068 23: sdispls = (int *) ADIOI_Malloc( nprocs * sizeof(int) );
1073 29: all_send_buf = (char *) ADIOI_Malloc( stail );
Total found: 23
-- Rob Latham Mathematics and Computer Science Division Argonne National Lab, IL USA
participants (1)
Kevin Harms
