Re: [mpich-devel] [mpich2-dev] And yet another ROMIO performance question
On Wed, Sep 16, 2009 at 02:57:45PM -0500, Bob Cernohous wrote:
Same customer noticed that the file system was doing much more i/o than MPIIO on collective reads.
Hi Bob. Did you ever get an acceptable answer to this 4 year old question? Have you ever had anyone respond to a 4 year old message? Let's see how well lotus notes handles /that/. Sorry it took me so long to give you an answer. By the time I figured out what was going on, I forgot you needed an answer. In my meager defense, my daughter was 6 weeks old back then.... What happens is two-phase implements data sieving. Normally, this is good. On Blue Gene, we turn on two-phase all the time (the hint is "enable", not "automatic"), even when accesses are not overlapping. So, consider a file domain where the first and last bytes are written. (e.g. a parallel-netcdf application is reading from a file with record variables). ROMIO will issue one read for the entire file domain. Writes are even worse: ROMIO will read in the entire file domain, modify the regions, and write it out. Not sure the best way to fix this. Probably stick in a few peephole optimizations, like if there's only one access in a file domain, just go ahead and issue that one access. A "real" fix would have to build up a basic performance model so we could answer the question of where the tradeoff of "big request with extra wasted data" beats "many small requests, but no wasted data". ==rob -- Rob Latham Mathematics and Computer Science Division Argonne National Lab, IL USA
participants (1)
Rob Latham
