Re: [mpich-devel] hwloc build failing on Mac with GCC
I'll just note that building on our OSX 10.7.4 test environment doesn't show any issues in this configuration. ----- Original Message -----
From: "Jeff Hammond" <[email protected]> To: [email protected] Sent: Wednesday, July 31, 2013 4:00:59 PM Subject: Re: [mpich-devel] hwloc build failing on Mac with GCC
Yes, that's right. Sorry. It's attached.
Jeff
From: "Ken Raffenetti" <[email protected]> To: [email protected] Sent: Wednesday, July 31, 2013 3:51:01 PM Subject: Re: [mpich-devel] hwloc build failing on Mac with GCC
Maybe I'm missing something, but I fail to find a problem in the attachment. Did you mean to attach a make log?
From: "Jeff Hammond" <[email protected]> To: "MPICH" <[email protected]> Sent: Wednesday, July 31, 2013 2:43:55 PM Subject: [mpich-devel] hwloc build failing on Mac with GCC
Am I stupid or is something broken? This is the git head as of a few minutes ago.
Note that the essence of the problem is in the attachment. I will not repeat it here.
Jeff
Jeffs-MacBook-Pro:build-gcc jhammond$ gcc -v Using built-in specs. COLLECT_GCC=gcc COLLECT_LTO_WRAPPER=/opt/local/libexec/gcc/x86_64-apple-darwin11/4.8.1/lto-wrapper Target: x86_64-apple-darwin11 Configured with: ../gcc-4.8.1/configure --prefix=/opt/local --build=x86_64-apple-darwin11 --enable-languages=c,c++,objc,obj-c++,lto,fortran,java --libdir=/opt/local/lib/gcc48 --includedir=/opt/local/include/gcc48 --infodir=/opt/local/share/info --mandir=/opt/local/share/man --datarootdir=/opt/local/share/gcc-4.8 --with-local-prefix=/opt/local --with-system-zlib --disable-nls --program-suffix=-mp-4.8 --with-gxx-include-dir=/opt/local/include/gcc48/c++/ --with-gmp=/opt/local --with-mpfr=/opt/local --with-mpc=/opt/local --with-ppl=/opt/local --with-cloog=/opt/local --enable-cloog-backend=isl --disable-cloog-version-check --enable-stage1-checking --disable-multilib --enable-lto --enable-libstdcxx-time --with-as=/opt/local/bin/as --with-ld=/opt/local/bin/ld --with-ar=/opt/local/bin/ar --with-bugurl=https://trac.macports.org/newticket --with-pkgversion='MacPorts gcc48 4.8.1_1' Thread model: posix gcc version 4.8.1 (MacPorts gcc48 4.8.1_1) Jeffs-MacBook-Pro:build-gcc jhammond$ g++ -v Using built-in specs. COLLECT_GCC=g++ COLLECT_LTO_WRAPPER=/opt/local/libexec/gcc/x86_64-apple-darwin11/4.8.1/lto-wrapper Target: x86_64-apple-darwin11 Configured with: ../gcc-4.8.1/configure --prefix=/opt/local --build=x86_64-apple-darwin11 --enable-languages=c,c++,objc,obj-c++,lto,fortran,java --libdir=/opt/local/lib/gcc48 --includedir=/opt/local/include/gcc48 --infodir=/opt/local/share/info --mandir=/opt/local/share/man --datarootdir=/opt/local/share/gcc-4.8 --with-local-prefix=/opt/local --with-system-zlib --disable-nls --program-suffix=-mp-4.8 --with-gxx-include-dir=/opt/local/include/gcc48/c++/ --with-gmp=/opt/local --with-mpfr=/opt/local --with-mpc=/opt/local --with-ppl=/opt/local --with-cloog=/opt/local --enable-cloog-backend=isl --disable-cloog-version-check --enable-stage1-checking --disable-multilib --enable-lto --enable-libstdcxx-time --with-as=/opt/local/bin/as --with-ld=/opt/local/bin/ld --with-ar=/opt/local/bin/ar --with-bugurl=https://trac.macports.org/newticket --with-pkgversion='MacPorts gcc48 4.8.1_1' Thread model: posix gcc version 4.8.1 (MacPorts gcc48 4.8.1_1) Jeffs-MacBook-Pro:build-gcc jhammond$ gfortran -v Using built-in specs. COLLECT_GCC=gfortran COLLECT_LTO_WRAPPER=/opt/local/libexec/gcc/x86_64-apple-darwin11/4.8.1/lto-wrapper Target: x86_64-apple-darwin11 Configured with: ../gcc-4.8.1/configure --prefix=/opt/local --build=x86_64-apple-darwin11 --enable-languages=c,c++,objc,obj-c++,lto,fortran,java --libdir=/opt/local/lib/gcc48 --includedir=/opt/local/include/gcc48 --infodir=/opt/local/share/info --mandir=/opt/local/share/man --datarootdir=/opt/local/share/gcc-4.8 --with-local-prefix=/opt/local --with-system-zlib --disable-nls --program-suffix=-mp-4.8 --with-gxx-include-dir=/opt/local/include/gcc48/c++/ --with-gmp=/opt/local --with-mpfr=/opt/local --with-mpc=/opt/local --with-ppl=/opt/local --with-cloog=/opt/local --enable-cloog-backend=isl --disable-cloog-version-check --enable-stage1-checking --disable-multilib --enable-lto --enable-libstdcxx-time --with-as=/opt/local/bin/as --with-ld=/opt/local/bin/ld --with-ar=/opt/local/bin/ar --with-bugurl=https://trac.macports.org/newticket --with-pkgversion='MacPorts gcc48 4.8.1_1' Thread model: posix gcc version 4.8.1 (MacPorts gcc48 4.8.1_1) Jeffs-MacBook-Pro:build-gcc jhammond$ uname -a Darwin Jeffs-MacBook-Pro.local 11.4.2 Darwin Kernel Version 11.4.2: Thu Aug 23 16:25:48 PDT 2012; root:xnu-1699.32.7~1/RELEASE_X86_64 x86_64
-- Jeff Hammond Argonne Leadership Computing Facility University of Chicago Computation Institute [email protected] / (630) 252-5381 http://www.linkedin.com/in/jeffhammond https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond ALCF docs: http://www.alcf.anl.gov/user-guides
participants (1)
Ken Raffenetti
