Re: [mpich-devel] ROMIO collective i/o memory use
I believe that I am on record as complaining vigorously about O(nproc) allocations in BG-MPICH. However, my first rule of parallel IO is to not do IO, so you will not hear me complain about this specific set of issues unless they are due to O(nproc) allocations inside of MPI collectives. Jeff On Mon, Apr 29, 2013 at 10:28 AM, Bob Cernohous <[email protected]> wrote:
A customer (Argonne ;) is complaining about O(p) allocations in collective i/o. A collective read is failing at larger scale.
Any thoughts or comments or advice? There appears to be lots of O(p) in ROMIO collective I/O. Plus a lot of (possibly large) aggregated data buffers. A quick search shows
The common ROMIO read collective code:
Find all "ADIOI_Malloc", Match case, Regular expression (UNIX) File Z:\bgq\comm\lib\dev\mpich2\src\mpi\romio\adio\common\ad_read_coll.c 124 38: st_offsets = (ADIO_Offset *) ADIOI_Malloc(nprocs*sizeof(ADIO_Offset)); 125 39: end_offsets = (ADIO_Offset *) ADIOI_Malloc(nprocs*sizeof(ADIO_Offset)); 317 44: *offset_list_ptr = (ADIO_Offset *) ADIOI_Malloc(2*sizeof(ADIO_Offset)); 318 41: *len_list_ptr = (ADIO_Offset *) ADIOI_Malloc(2*sizeof(ADIO_Offset)); 334 44: *offset_list_ptr = (ADIO_Offset *) ADIOI_Malloc(2*sizeof(ADIO_Offset)); 335 41: *len_list_ptr = (ADIO_Offset *) ADIOI_Malloc(2*sizeof(ADIO_Offset)); 436 18: ADIOI_Malloc((contig_access_count+1)*sizeof(ADIO_Offset)); 437 41: *len_list_ptr = (ADIO_Offset *) ADIOI_Malloc((contig_access_count+1)*sizeof(ADIO_Offset)); 573 37: if (ntimes) read_buf = (char *) ADIOI_Malloc(coll_bufsize); 578 21: count = (int *) ADIOI_Malloc(nprocs * sizeof(int)); 587 25: send_size = (int *) ADIOI_Malloc(nprocs * sizeof(int)); 590 25: recv_size = (int *) ADIOI_Malloc(nprocs * sizeof(int)); 598 25: start_pos = (int *) ADIOI_Malloc(nprocs*sizeof(int)); 739 32: tmp_buf = (char *) ADIOI_Malloc(for_next_iter); 744 33: read_buf = (char *) ADIOI_Malloc(for_next_iter+coll_bufsize); 805 9: ADIOI_Malloc((nprocs_send+nprocs_recv+1)*sizeof(MPI_Request)); 827 30: recv_buf = (char **) ADIOI_Malloc(nprocs * sizeof(char*)); 830 44: (char *) ADIOI_Malloc(recv_size[i]); 870 31: statuses = (MPI_Status *) ADIOI_Malloc((nprocs_send+nprocs_recv+1) * \ 988 35: curr_from_proc = (unsigned *) ADIOI_Malloc(nprocs * sizeof(unsigned)); 989 35: done_from_proc = (unsigned *) ADIOI_Malloc(nprocs * sizeof(unsigned)); 990 35: recv_buf_idx = (unsigned *) ADIOI_Malloc(nprocs * sizeof(unsigned)); Total found: 22
Our BG version of read collective:
File Z:\bgq\comm\lib\dev\mpich2\src\mpi\romio\adio\ad_bg\ad_bg_rdcoll.c 179 40: st_offsets = (ADIO_Offset *) ADIOI_Malloc(nprocs*sizeof(ADIO_Offset)); 180 40: end_offsets = (ADIO_Offset *) ADIOI_Malloc(nprocs*sizeof(ADIO_Offset)); 183 43: bg_offsets0 = (ADIO_Offset *) ADIOI_Malloc(2*nprocs*sizeof(ADIO_Offset)); 184 43: bg_offsets = (ADIO_Offset *) ADIOI_Malloc(2*nprocs*sizeof(ADIO_Offset)); 475 37: if (ntimes) read_buf = (char *) ADIOI_Malloc(coll_bufsize); 480 21: count = (int *) ADIOI_Malloc(nprocs * sizeof(int)); 489 25: send_size = (int *) ADIOI_Malloc(nprocs * sizeof(int)); 492 25: recv_size = (int *) ADIOI_Malloc(nprocs * sizeof(int)); 500 25: start_pos = (int *) ADIOI_Malloc(nprocs*sizeof(int)); 676 32: tmp_buf = (char *) ADIOI_Malloc(for_next_iter); 681 33: read_buf = (char *) ADIOI_Malloc(for_next_iter+coll_bufsize); 761 9: ADIOI_Malloc((nprocs_send+nprocs_recv+1)*sizeof(MPI_Request)); 783 30: recv_buf = (char **) ADIOI_Malloc(nprocs * sizeof(char*)); 786 44: (char *) ADIOI_Malloc(recv_size[i]); 826 31: statuses = (MPI_Status *) ADIOI_Malloc((nprocs_send+nprocs_recv+1) * \ 944 35: curr_from_proc = (unsigned *) ADIOI_Malloc(nprocs * sizeof(unsigned)); 945 35: done_from_proc = (unsigned *) ADIOI_Malloc(nprocs * sizeof(unsigned)); 946 35: recv_buf_idx = (unsigned *) ADIOI_Malloc(nprocs * sizeof(unsigned)); 1058 23: rdispls = (int *) ADIOI_Malloc( nprocs * sizeof(int) ); 1063 29: all_recv_buf = (char *) ADIOI_Malloc( rtail ); 1064 26: recv_buf = (char **) ADIOI_Malloc(nprocs * sizeof(char *)); 1068 23: sdispls = (int *) ADIOI_Malloc( nprocs * sizeof(int) ); 1073 29: all_send_buf = (char *) ADIOI_Malloc( stail ); Total found: 23
Bob Cernohous: (T/L 553) 507-253-6093
[email protected] IBM Rochester, Building 030-2(C335), Department 61L 3605 Hwy 52 North, Rochester, MN 55901-7829
Chaos reigns within. Reflect, repent, and reboot. Order shall return.
-- Jeff Hammond Argonne Leadership Computing Facility University of Chicago Computation Institute [email protected] / (630) 252-5381 http://www.linkedin.com/in/jeffhammond https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond ALCF docs: http://www.alcf.anl.gov/user-guides
participants (1)
Jeff Hammond
