Re: [mpich-devel] Hydra fails to launch hello world on 1 proc
Oh, I should also have suggested the preliminary step of running: "mpiexec -v -n 1 hostname" Based on the strace output, it looks like hydra is trying to ssh to the local machine and that ssh connection is simply hanging for some reason (try manually ssh-ing to goldstone.mcs.anl.gov). ----8<---- execve("/usr/bin/ssh", ["/usr/bin/ssh", "-x", "goldstone.mcs.anl.gov", "\"/home/jeff/eclipse/MPICH/git/in"..., "--control-port", "goldstone.mcs.anl.gov:51163", "--rmk", "user", "--launcher", "ssh", "--demux", "poll", "--pgid", "0", "--retries", "10", ...], [/* 108 vars */]) = 0 […] socket(PF_INET, SOCK_STREAM, IPPROTO_TCP) = 3 fcntl(3, F_SETFD, FD_CLOEXEC) = 0 connect(3, {sa_family=AF_INET, sin_port=htons(22), sin_addr=inet_addr("140.221.3.26")}, 16 ----8<---- I'm not sure why hydra is trying to use ssh for a single (same) node mpiexec. Some/all of that may also have been clear from the "mpiexec -v" output. -Dave On Apr 10, 2013, at 10:45 PM CDT, Jeff Hammond <[email protected]> wrote:
Not sure if this helps at all. It makes no sense to me.
Jeff
On Wed, Apr 10, 2013 at 9:33 PM, Dave Goodell <[email protected]> wrote:
Linux or Mac? If it's Linux, an "strace -f -ff -o strace.out mpiexec -n 1 hostname" might shed some light on the situation.
-Dave
On Apr 10, 2013, at 10:30 PM CDT, Jeff Hammond <[email protected]> wrote:
"mpiexec -n 1 hostname" hangs with Hydra but runs fine with OpenMPI.
I'm having issues with MPI+Pthreads code with both MPICH and OpenMPI that indicates that my system is not behaving as others do, but I'll need to do a lot more work to figure out what the important differences are.
Jeff
On Wed, Apr 10, 2013 at 9:24 PM, Dave Goodell <[email protected]> wrote:
Does it run non-MPI jobs OK? ("mpiexec -n 1 hostname", for example)
Is this Linux or a Mac?
If you temporarily disable the firewall, does that make a difference?
-Dave
On Apr 10, 2013, at 6:34 PM CDT, Jeff Hammond <[email protected]> wrote:
I'm using the latest Git trunk build of MPICH with GCC and am unable to run a 'hello, world' program using mpiexec.
Any clues what the problem is? I have not seen this problem before, but this is newly refreshed laptop. The firewall is active but I would not have expected Hydra to need to go through the firewall to launch a serial job.
If there's something wrong with my setup, it would be nice if Hydra would issue a warning/error instead of handing.
Jeff
I compiled MPICH like this: ../configure CC=gcc CXX=g++ FC=gfortran F77=gfortran --enable-threads --enable-f77 --enable-fc --enable-g --with-pm=hydra --enable-rpath --disable-static --enable-shared --with-device=ch3:nemesis --prefix=/home/jeff/eclipse/MPICH/git/install-gcc
jeff@goldstone:~/eclipse/OSPRI/mcs.svn/trunk/tests/devices/mpi-pt> mpicc -show gcc -I/home/jeff/eclipse/MPICH/git/install-gcc/include -L/home/jeff/eclipse/MPICH/git/install-gcc/lib64 -Wl,-rpath -Wl,/home/jeff/eclipse/MPICH/git/install-gcc/lib64 -lmpich -lopa -lmpl -lrt -lpthread
jeff@goldstone:~/eclipse/OSPRI/mcs.svn/trunk/tests/devices/mpi-pt> make mpicc -g -O0 -Wall -std=gnu99 -DDEBUG -c hello.c -o hello.o mpicc -g -O0 -Wall -std=gnu99 safemalloc.o hello.o -lm -o hello.x rm hello.o
jeff@goldstone:~/eclipse/OSPRI/mcs.svn/trunk/tests/devices/mpi-pt> mpiexec -n 1 ./hello.x ^C[[email protected]] Sending Ctrl-C to processes as requested [[email protected]] Press Ctrl-C again to force abort [[email protected]] HYDU_sock_write (../../../../src/pm/hydra/utils/sock/sock.c:291): write error (Bad file descriptor) [[email protected]] HYD_pmcd_pmiserv_send_signal (../../../../src/pm/hydra/pm/pmiserv/pmiserv_cb.c:170): unable to write data to proxy [[email protected]] ui_cmd_cb (../../../../src/pm/hydra/pm/pmiserv/pmiserv_pmci.c:79): unable to send signal downstream [[email protected]] HYDT_dmxu_poll_wait_for_event (../../../../src/pm/hydra/tools/demux/demux_poll.c:77): callback returned error status [[email protected]] HYD_pmci_wait_for_completion (../../../../src/pm/hydra/pm/pmiserv/pmiserv_pmci.c:197): error waiting for event [[email protected]] main (../../../../src/pm/hydra/ui/mpich/mpiexec.c:331): process manager error waiting for completion
jeff@goldstone:~/eclipse/OSPRI/mcs.svn/trunk/tests/devices/mpi-pt> ./hello.x <no errors>
jeff@goldstone:~/eclipse/OSPRI/mcs.svn/trunk/tests/devices/mpi-pt> cat hello.c #include <stdio.h> #include <stdlib.h>
#include <mpi.h>
int main(int argc, char * argv[]) { int provided;
MPI_Init_thread(&argc, &argv, MPI_THREAD_MULTIPLE, &provided); if (provided!=MPI_THREAD_MULTIPLE) MPI_Abort(MPI_COMM_WORLD, 1);
int rank, size; MPI_Comm_rank(MPI_COMM_WORLD, &rank); MPI_Comm_size(MPI_COMM_WORLD, &size);
MPI_Finalize();
return 0; }
-- Jeff Hammond Argonne Leadership Computing Facility University of Chicago Computation Institute [email protected] / (630) 252-5381 http://www.linkedin.com/in/jeffhammond https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond
-- Jeff Hammond Argonne Leadership Computing Facility University of Chicago Computation Institute [email protected] / (630) 252-5381 http://www.linkedin.com/in/jeffhammond https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond <strace.out.11831><strace.out.11832>
participants (1)
Dave Goodell
