Re: [mpich-devel] LLONG_MAX undeclared in status_set_elements_x.c ?
This is my setup and what I see: [jhammond@flogin3 build-gcc]$ uname -a Linux flogin3 2.6.18-274.18.1.el5 #1 SMP Fri Jan 20 15:11:18 EST 2012 x86_64 x86_64 x86_64 GNU/Linux [jhammond@flogin3 build-gcc]$ svn info .. Path: .. URL: https://svn.mcs.anl.gov/repos/mpi/mpich2/trunk Repository Root: https://svn.mcs.anl.gov/repos/mpi Repository UUID: a5d90c62-d51d-0410-9f91-bf5351168976 Revision: 10808 Node Kind: directory Schedule: normal Last Changed Author: dinan Last Changed Rev: 10808 Last Changed Date: 2012-12-28 22:21:55 -0600 (Fri, 28 Dec 2012) [jhammond@flogin3 build-gcc]$ which gcc /soft/gcc/4.4.2/bin/gcc [jhammond@flogin3 build-gcc]$ gcc --version gcc (GCC) 4.4.2 Copyright (C) 2009 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. [jhammond@flogin3 build-gcc]$ ../configure --enable-threads --enable-g --prefix=/homes/jhammond/MPI/mpich2-trunk/install-gcc && make -j8 && make install <snip> CC src/mpi_t/mpi_t_util.lo CC src/nameserv/file/file_nameserv.lo CC src/pmi/simple/simple_pmiutil.lo CC src/pmi/simple/simple_pmi.lo CC src/mpi/datatype/status_set_elements_x.lo CC src/mpi/datatype/type_indexed.lo CC src/mpi/datatype/type_hindexed.lo CC src/mpi/datatype/type_struct.lo CC src/mpi/datatype/type_contiguous.lo CC src/mpi/datatype/type_free.lo CC src/mpi/datatype/type_hvector.lo ../src/mpi/datatype/status_set_elements_x.c: In function 'MPIR_Status_set_elements_x_impl': ../src/mpi/datatype/status_set_elements_x.c:41: error: 'LLONG_MAX' undeclared (first use in this function) ../src/mpi/datatype/status_set_elements_x.c:41: error: (Each undeclared identifier is reported only once ../src/mpi/datatype/status_set_elements_x.c:41: error: for each function it appears in.) make[2]: *** [src/mpi/datatype/status_set_elements_x.lo] Error 1 make[2]: *** Waiting for unfinished jobs.... make[2]: Leaving directory `/fusion/gpfs/home/jhammond/MPI/mpich2-trunk/build-gcc' make[1]: *** [all-recursive] Error 1 make[1]: Leaving directory `/fusion/gpfs/home/jhammond/MPI/mpich2-trunk/build-gcc' make: *** [all] Error 2 Jeff On Mon, Dec 31, 2012 at 2:07 PM, William Gropp <[email protected]> wrote:
I've committed the change that tests for LLONG_MAX - in r10802 . What error are you seeing?
Bill
William Gropp Director, Parallel Computing Institute Deputy Director for Research Institute for Advanced Computing Applications and Technologies Paul and Cynthia Saylor Professor of Computer Science University of Illinois Urbana-Champaign
On Dec 31, 2012, at 1:37 PM, Jeff Hammond wrote:
I did a fresh checkout today and am still seeing this issue. What's the workaround until it is fixed for real?
I am working on Fusion at Argonne using "../configure --enable-threads --enable-g" and GCC 4.4.2 compilers, btw.
Jeff
On Fri, Dec 21, 2012 at 8:22 AM, William Gropp <[email protected]> wrote:
Thanks. This test erroneously uses long long and LLONG_MAX without ensuring that they are available (and for which the configure for the tests already checks). I'll fix it.
Bill
On Dec 21, 2012, at 2:25 AM, P.-H. Lin wrote:
Hello Howard, I have encountered the same problem with mpich-3.0.1 today. (And that's why I found this thread :P) After raising the optimization level, it didn't complain about that undeclared problem anymore, and the installation goes well. This is my configure option: ./configure --prefix /opt/app/MPICH --enable-fast=all,O3
BTW, the problem still exist for "indexed-misc.c" under the test directory
Regards
-- Jeff Hammond Argonne Leadership Computing Facility University of Chicago Computation Institute [email protected] / (630) 252-5381 http://www.linkedin.com/in/jeffhammond https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond
participants (1)
Jeff Hammond
