Re: [mpich-devel] Assertion failed in file src/mpid/ch3/channels/nemesis/src/ch3_progress.c at line 643: pkt->type >= 0 && pkt->type < MPIDI_CH3_PKT_END_ALL internal ABORT - process 1
Build info: MPICH Version: 3.2b3 MPICH Release date: Thu Jun 4 07:59:11 CDT 2015 MPICH Device: ch3:nemesis MPICH configure: --prefix=/usr --sysconfdir=/etc --libdir=/usr/lib --mandir=/usr/share/man --infodir=/usr/share/info --docdir=/usr/share/doc/mpich --htmldir=/usr/share/doc/mpich --dvidir=/usr/share/doc/mpich --pdfdir=/usr/share/doc/mpich --psdir=/usr/share/doc/mpich MPICH CC: gcc -O2 MPICH CXX: g++ -O2 MPICH F77: gfortran -O2 MPICH FC: gfortran -O2 gcc -I/usr/include -L/usr/lib -Wl,-rpath -Wl,/usr/lib -Wl,--enable-new-dtags -lmpi On Tue, Dec 29, 2015 at 12:44 PM, Jeff Hammond <[email protected]> wrote:
I do not, but I guess Marcelo Soares Souza does ( http://lists.mpich.org/pipermail/discuss/2015-June/004045.html).
Travis will log the output of mpichversion the next time it runs...
Jeff
On Tue, Dec 29, 2015 at 12:17 PM, Balaji, Pavan <[email protected]> wrote:
Do you have more details on how mpich was built?
-- Pavan
On Dec 29, 2015, at 2:05 PM, Jeff Hammond <[email protected]> wrote:
I am using mpich_3.2b3-1ubuntu_amd64.deb within Travis CI for ARMCI-MPI testing. I never saw this problem in Jenkins, so I can't tell if the problem is specific to the deb build, to Travis, or something else.
Travis page has all the details so I will not repeat them here.
Jeff
From https://travis-ci.org/jeffhammond/armci-mpi/jobs/99316268:
Processing triggers for libc-bin ... ldconfig deferred processing now taking place +wget -q http://www.cebacad.net/files/mpich/ubuntu/mpich-3.2b3/mpich_3.2b3-1ubuntu_am... +sudo dpkg -i ./mpich_3.2b3-1ubuntu_amd64.deb Selecting previously unselected package mpich. (Reading database ... 124680 files and directories currently installed.) Unpacking mpich (from .../mpich_3.2b3-1ubuntu_amd64.deb) ... Setting up mpich (3.2b3-1ubuntu) ... Processing triggers for man-db ...
FAIL: benchmarks/contiguous-bench (exit: 1) =========================================== ARMCI-MPI initialized with 2 processes, MPI v3.1 PROGRESS_THREAD = DISABLED ALLOC_SHM used = TRUE WINDOW type used = CREATE STRIDED_METHOD = DIRECT IOV_METHOD = DIRECT IOV_CHECKS = FALSE SHR_BUF_METHOD = COPY NONCOLLECTIVE_GROUPS = FALSE CACHE_RANK_TRANSLATION = TRUE DEBUG_ALLOC = FALSE Starting one-sided contiguous performance test with 2 processes Trg. Rank Xfer Size Get (usec) Put (usec) Acc (usec) Get (MiB/s) Put (MiB/s) Acc (MiB/s) 1 8 0.869 0.707 0.935 8.783 10.795 8.158 1 16 0.926 0.768 0.914 16.482 19.859 16.698 1 32 0.945 0.856 0.974 32.284 35.671 31.336 1 64 0.938 0.781 0.956 65.097 78.199 63.852 1 128 0.946 0.833 1.055 128.992 146.623 115.730 1 256 0.969 0.819 1.065 251.986 297.954 229.235 1 512 0.953 0.867 1.024 512.188 562.918 477.005 1 1024 0.995 0.873 1.139 981.813 1119.078 857.161 1 2048 1.010 0.850 1.044 1932.970 2297.619 1870.578 1 4096 1.071 1.172 1.494 3647.221 3334.105 2614.495 1 8192 1.634 1.721 2.068 4780.515 4539.290 3777.801 1 16384 2.989 3.325 4.856 5227.361 4698.842 3217.416 1 32768 5.321 7.480 9.465 5872.833 4177.594 3301.464 1 65536 13.295 14.356 20.259 4701.146 4353.478 3085.039 1 131072 23.574 31.835 45.756 5302.534 3926.447 2731.862 1 262144 44.921 70.181 102.028 5565.275 3562.231 2450.313 Assertion failed in file src/mpid/ch3/channels/nemesis/src/ch3_progress.c at line 643: pkt->type >= 0 && pkt->type < MPIDI_CH3_PKT_END_ALL internal ABORT - process 1
-- Jeff Hammond [email protected] http://jeffhammond.github.io/ _______________________________________________ To manage subscription options or unsubscribe: https://lists.mpich.org/mailman/listinfo/devel
participants (1)
Jeff Hammond
