Re: [mpich-devel] Collective i/o failure
On Thu, Jul 25, 2013 at 09:16:22AM -0500, Bob Cernohous wrote:
Question. If a rank fails a collective i/o, does it make sense for all ranks to fail that collective i/o? Or just the single rank? The problem with just a single rank failing is the remaining ranks likely get hung in some internal collective call. I'm wondering if having all ranks fail is *better*?
In write_all in particular:
http://git.mpich.org/mpich.git/blob/HEAD:/src/mpi/romio/mpi-io/write_all.c#l...
89 if (file_ptr_type == ADIO_EXPLICIT_OFFSET && offset < 0) 90 { 91 error_code = MPIO_Err_create_code(MPI_SUCCESS, MPIR_ERR_RECOVERABLE, 92 myname, __LINE__, MPI_ERR_ARG, 93 "**iobadoffset", 0); 94 error_code = MPIO_Err_return_file(adio_fh, error_code); 95 goto fn_exit; 96 } 97 /* --END ERROR HANDLING-- */
We *could* allreduce the offset and fail all ranks if any rank has a negative offset. Not sure that's the right answer.
There are some places already in the I/O path where we collectively check the parameters, such as a check to ensure all processes open/create a file with the same AMODE. Adding more collectives to the I/O path might make sense, but should be done carefully. I recently added MPIO_CHECK_INFO_ALL to address an IBM-reported bug, so CHECK_OFFSET_ALL would not be without precedent.
What happened was a single rank failed, the remaining ranks entered a (hardware-based) allreduce.
How did this single rank get a negative offset? Was there some integer math that overflowed?
The failing rank happened to enter an application (hardware-based) allreduce and you get a hardware detected failure that no app developer is going to even try to decode and debug. So I get the call. Without the hardware involved, it just hangs on two independent allreduces. They might have figured that one out by looking at where the (hundreds/thousands of) stacks were hung. Of course, they didn't actually check the return from the write_all :) Although I'm not sure how MPIR_ERR_RECOVERABLE it is at that point.
In parallel-netcdf I chose to force the caller to check errors so that I could avoid an allreduce inside pnetcdf. That seemed like the right thing to do for pnetcdf.
Just wondering if there's something I can fix here in addition to the application.
Bob Cernohous: (T/L 553) 507-253-6093
[email protected] IBM Rochester, Building 030-2(C335), Department 61L 3605 Hwy 52 North, Rochester, MN 55901-7829
Chaos reigns within. Reflect, repent, and reboot. Order shall return.
-- Rob Latham Mathematics and Computer Science Division Argonne National Lab, IL USA
participants (1)
Rob Latham
