ifort: error #10236: File not found: 'src/binding/fortran/use_mpi_f08/mpi_f08_types.f90'
I cannot configure MPICH due to any F08-related issue. I ran autogen.sh twice just to be darn sure I wasn't making that mistake again. This is with the latest MPICH git master. I am using Intel Fortran 16 on Mac Yosemite. The GCC 5.2 build was fine so this might be related to ifort, but it's not obvious why. Thanks, Jeff This is how I attempted to configure: jrhammon-mac01:build jrhammon$ head config.log This file contains any messages produced by compilers while running configure, to aid debugging if configure makes a mistake. It was created by MPICH configure 3.2rc1, which was generated by GNU Autoconf 2.69. Invocation command line was $ ../configure CC=icc CXX=icpc FC=ifort F77=ifort --enable-cxx --enable-fortran --enable-threads=runtime --enable-g=dbg --with-pm=hydra --prefix=/opt/mpich/dev/intel/default --enable-wrapper-rpath --enable-static --enable-shared Here is the error: Configuration completed. MOD src/binding/fortran/use_mpi_f08/mpi_c_interface_types.stamp MOD src/binding/fortran/use_mpi_f08/mpi_f08_types.stamp ifort: error #10236: File not found: 'src/binding/fortran/use_mpi_f08/mpi_f08_types.f90' ifort: command line error: no files specified; for help type "ifort -help" make: *** [src/binding/fortran/use_mpi_f08/mpi_f08_types.stamp] Error 1 -- Jeff Hammond [email protected] http://jeffhammond.github.io/
participants (1)
Jeff Hammond
