Re: [mpich-devel] MPI_Pack/MPI_Unpack/MPI_Pack_size and large datatypes
On Oct 18, 2013, at 8:15 PM, Rob Latham wrote:
On Fri, Oct 18, 2013 at 04:44:32PM -0500, Pavan Balaji wrote:
Hi Rob,
I totally agree with adding this into MPICH.
However, with respect to the MPI standard, can one not implement MPIX_Pack_x on top of current MPI-3 using appropriate datatype creation?
It'd have to be "next to" or "inside", but not "on top of". The usual trick of "just describe big type with a smaller number of CONTIGs won't work:
MPI_Pack(const void *inbuf, int incount, MPI_Datatype datatype, void * outbuf, int outcount int *position);
We're ok on inputs: a normal buf, count, datatype tuple.
How do you work around the output, though? outcount is a count of bytes, not a count of datatypes. Position is a plain old pointer to memory.
I meant, one can write a higher-level function that takes Aint, which internally uses a combination of MPI_Pack and MPI_Get_elements_x. No? -- Pavan -- Pavan Balaji http://www.mcs.anl.gov/~balaji
participants (1)
Pavan Balaji
