Re: [mpich-devel] [PATCH] ofi: need to specify ordering for FI_EP_RDM
On 09/04/2015 10:16 AM, Jeff Squyres (jsquyres) wrote:
Just curious, what's the process for getting this patch accepted into MPICH?
We have a formal workflow for frequent contributors that involves sign-offs and such. For occasional contributions, sending a patch to devel@mpich (as you did) works great. Ken's going to review this. ==rob
Thanks.
On Sep 3, 2015, at 1:24 PM, Jeff Squyres (jsquyres) <[email protected]> wrote:
Per https://github.com/ofiwg/libfabric/issues/1217#issuecomment-131264316, you really need to specify FI_ORDER_SAS for both transmit and receive if you want to guarantee ordering on FI_EP_RDM endpoints (and you do; the MPI-style tagging interface doesn't make much sense unless the underlying fabric provider guarnatees ordering).
Signed-off-by: Jeff Squyres <[email protected]> --- src/mpid/ch3/channels/nemesis/netmod/ofi/ofi_init.c | 10 ++++++---- 1 file changed, 6 insertions(+), 4 deletions(-)
diff --git a/src/mpid/ch3/channels/nemesis/netmod/ofi/ofi_init.c b/src/mpid/ch3/channels/nemesis/netmod/ofi/ofi_init.c index 5de47b7..2cf3337 100644 --- a/src/mpid/ch3/channels/nemesis/netmod/ofi/ofi_init.c +++ b/src/mpid/ch3/channels/nemesis/netmod/ofi/ofi_init.c @@ -77,10 +77,12 @@ int MPID_nem_ofi_init(MPIDI_PG_t * pg_p, int pg_rank, char **bc_val_p, int *val_ /* We expect to register all memory up front for use with this */ /* endpoint, so the netmod requires dynamic memory regions */ /* ------------------------------------------------------------------------ */ - hints = fi_allocinfo(); - hints->mode = FI_CONTEXT; - hints->ep_attr->type = FI_EP_RDM; /* Reliable datagram */ - hints->caps = FI_TAGGED; /* Tag matching interface */ + hints = fi_allocinfo(); + hints->mode = FI_CONTEXT; + hints->ep_attr->type = FI_EP_RDM; /* Reliable datagram */ + hints->caps = FI_TAGGED; /* Tag matching interface */ + hints->tx_attr->msg_order = FI_ORDER_SAS; + hints->rx_attr->msg_order = FI_ORDER_SAS;
hints->ep_attr->mem_tag_format = MEM_TAG_FORMAT; MPIU_Assert(pg_p->size < ((1 << MPID_RANK_BITS) - 1)); -- 2.4.3
-- Rob Latham Mathematics and Computer Science Division Argonne National Lab, IL USA
participants (1)
Rob Latham
