Re: [mpich-devel] Collective i/o failure
Hi, No, discussions of whether we should be checking that parameters are valid in a collective way, so that we can give a proper error back to all ranks in the case where one rank has a problem. It is not generally the case that collectives are free. This type of error checking has been done in add-on libraries, for example, to help in debugging. I think A. Chan et al. did an instance of this some time back. Rob On Jul 25, 2013, at 1:57 PM, Jeff Hammond wrote:
BG-specific discussions? I don't care what the Forum thinks about an implementation detail that makes BG more productive for our users.
If MPIO_CHECK_OFFSET_ALL is optional and IBM chooses to enable it, what does that matter to anyone else?
Jeff
----- Original Message -----
From: "Rob Ross" <[email protected]> To: [email protected] Sent: Thursday, July 25, 2013 2:31:16 PM Subject: Re: [mpich-devel] Collective i/o failure
See historical discussions on collective argument checking. -- Rob
On Jul 25, 2013, at 1:13 PM, Jeff Hammond wrote:
MPI_Allreduce on an integer should be almost infinitely fast on BG so maybe an ifdef guard is all that is required to keep this from standing in the way of widespread acceptance of MPI-IO.
Best,
Jeff
From: "Rob Ross" <[email protected]> To: [email protected] Sent: Thursday, July 25, 2013 2:03:40 PM Subject: Re: [mpich-devel] Collective i/o failure
Just to reiterate the point that RobL made: adding collectives to check for completion, etc. of other ranks adds overhead to the calls when they are successful. This in turn makes people not use MPI-IO, because it becomes slower, which is good for reducing bug reports, but bad for encouraging use of standard interfaces.
Rob
On Jul 25, 2013, at 12:10 PM, Bob Cernohous wrote:
How did this single rank get a negative offset? Was there some integer math that overflowed?
That's for the app developer to figure out. My issue is that if all ranks had failed the write he probably would have started figuring that out a few days ago and I wouldn't have gotten involved :) It's the weird hw error that dragged me into this when the non-failing ranks entered allreduce in romio and the failing ranks entered allreduce in the app.
Like I said :
Just wondering if there's something I can fix here in addition to the application.
Not the highest priority really. But I coincidentally just got another report (from ANL this time) that an app is hung with half the ranks in write_at_all and half the ranks in a later barrier. It could be something similar. I don't have enough information yet to know but I've suggested they look at errors from write.
-- Jeff Hammond Argonne Leadership Computing Facility University of Chicago Computation Institute [email protected] / (630) 252-5381 http://www.linkedin.com/in/jeffhammond https://wiki.alcf.anl.gov/parts/index.php/User:Jhammond ALCF docs: http://www.alcf.anl.gov/user-guides
participants (1)
Rob Ross
