Build failed in Jenkins: mpich-tarball #499
28 Apr
2021
28 Apr
'21
1:03 a.m.
See <https://jenkins-ci.cels.anl.gov/job/mpich-tarball/499/display/redirect?page=changes>
Changes:
[Kenneth J. Raffenetti] ch4/ucx: Fix temporary buffer allocation in AM path
[Kenneth J. Raffenetti] test: Add test to ensure MPI_PREADY does not block
[Kenneth J. Raffenetti] ch4/am: Use reply API for partitioned CTS message
[Kenneth J. Raffenetti] ch4/am: Simplify partitioned CTS API
[Kenneth J. Raffenetti] ch4/am: Make MPI_PREADY[*] nonblocking
Started by an SCM change
Running as SYSTEM
[EnvInject] - Loading node environment variables.
Building remotely on compute004.mcs.anl.gov (16.04 skylake-any-version) in workspace <https://jenkins-ci.cels.anl.gov/job/mpich-tarball/ws/>
The recommended git tool is: NONE
No credentials specified
Wiping out workspace first.
Cloning the remote Git repository
Cloning repository http://github.com/pmodels/mpich
> git init <https://jenkins-ci.cels.anl.gov/job/mpich-tarball/ws/> # timeout=10
Fetching upstream changes from http://github.com/pmodels/mpich
> git --version # timeout=10
> git --version # 'git version 2.7.4'
> git fetch --tags --progress http://github.com/pmodels/mpich +refs/heads/*:refs/remotes/origin/* # timeout=10
> git config remote.origin.url http://github.com/pmodels/mpich # timeout=10
> git config --add remote.origin.fetch +refs/heads/*:refs/remotes/origin/* # timeout=10
Avoid second fetch
Seen branch in repository origin/3.1.x
Seen branch in repository origin/3.2.x
Seen branch in repository origin/3.3.x
Seen branch in repository origin/3.4.x
Seen branch in repository origin/ecp-ft
Seen branch in repository origin/main
Seen branch in repository origin/master
Seen 7 remote branches
> git show-ref --tags -d # timeout=10
Checking out Revision da835387cad580adfb36740fda93b49d07013423 (origin/main)
> git config core.sparsecheckout # timeout=10
> git checkout -f da835387cad580adfb36740fda93b49d07013423 # timeout=10
> git branch -a -v --no-abbrev # timeout=10
> git checkout -b main da835387cad580adfb36740fda93b49d07013423 # timeout=10
Commit message: "Merge pull request #5232 from raffenet/nb-pready"
> git rev-list --no-walk 67b0790a5f75ec605f738200e6fe1b96977d5e3a # timeout=10
[mpich-tarball] $ /bin/bash -xe /tmp/jenkins265741742201204843.sh
+ umask 0002
+ git config core.abbrev 12
++ uname -m
+ export PATH=/homes/MPI/software/tools/install/x86_64/bin:/homes/jain/anaconda3/bin:/homes/jain/anaconda3/condabin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
+ PATH=/homes/MPI/software/tools/install/x86_64/bin:/homes/jain/anaconda3/bin:/homes/jain/anaconda3/condabin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
+ BASE=/mcs/mpich/downloads/nightly
+ persist_tmp=/mcs/mpich/tmp
+ '[' -d /mcs/mpich/tmp ']'
+ create_snapshot https://raw.githubusercontent.com/pmodels/mpich/main/maint/release.pl http://github.com/pmodels/mpich main main
+ script=https://raw.githubusercontent.com/pmodels/mpich/main/maint/release.pl
+ repo=http://github.com/pmodels/mpich
+ branch=main
+ version=main
+ cd /tmp
+ /mcs/mpich/downloads/nightly/maint/release.pl --git-repo=http://github.com/pmodels/mpich --branch=main --version=main --append-commit-id
Unescaped left brace in regex is deprecated, passed through in regex; marked by <-- HERE in m/\${ <-- HERE ([^ \t=:+{}]+)}/ at /homes/MPI/software/tools/install/x86_64/bin/automake line 3936.
unable to execute (cp -a doc/logging/logging.pdf /tmp/oO_W1ssU3H/mpich-main-v4.0a1-404-gda83538/doc/logging), $?=256. Stopped at /mcs/mpich/downloads/nightly/maint/release.pl line 118.
cannot remove path when cwd is /tmp/oO_W1ssU3H/mpich-main-v4.0a1-404-gda83538-build for /tmp/oO_W1ssU3H: at /usr/share/perl/5.22/File/Temp.pm line 778.
Build step 'Execute shell' marked build as failure
1914
Age (days ago)
1914
Last active (days ago)
0 comments
1 participants
participants (1)
sysadmin-notifications@lists.cels.anl.gov
