Build failed in Jenkins: mpich-tarball #539
15 Jun
2021
15 Jun
'21
1:03 a.m.
See <https://jenkins-ci.cels.anl.gov/job/mpich-tarball/539/display/redirect?page=changes>
Changes:
[hzhou321] config: fix PAC_APPEND_FLAG and PAC_PREPEND_FLAG
[hzhou321] test: proper integer cast in redscatbkinter.c and redscatinter.c
[hzhou321] env: add recursive checks in compiler scripts
[hzhou321] config: save USER_ flags after merging MPICHLIB_ flags
[hzhou321] typerep: add more platform dependent endian definitions
[hzhou321] typerep: cleanup endian definitions
Started by an SCM change
Running as SYSTEM
[EnvInject] - Loading node environment variables.
Building remotely on compute004.mcs.anl.gov (16.04 skylake-any-version) in workspace <https://jenkins-ci.cels.anl.gov/job/mpich-tarball/ws/>
The recommended git tool is: NONE
No credentials specified
Wiping out workspace first.
Cloning the remote Git repository
Cloning repository http://github.com/pmodels/mpich
> git init <https://jenkins-ci.cels.anl.gov/job/mpich-tarball/ws/> # timeout=10
Fetching upstream changes from http://github.com/pmodels/mpich
> git --version # timeout=10
> git --version # 'git version 2.7.4'
> git fetch --tags --progress http://github.com/pmodels/mpich +refs/heads/*:refs/remotes/origin/* # timeout=10
> git config remote.origin.url http://github.com/pmodels/mpich # timeout=10
> git config --add remote.origin.fetch +refs/heads/*:refs/remotes/origin/* # timeout=10
Avoid second fetch
Seen branch in repository origin/3.1.x
Seen branch in repository origin/3.2.x
Seen branch in repository origin/3.3.x
Seen branch in repository origin/3.4.x
Seen branch in repository origin/ecp-ft
Seen branch in repository origin/main
Seen branch in repository origin/master
Seen branch in repository origin/revert-5281-2105_part
Seen 8 remote branches
> git show-ref --tags -d # timeout=10
Checking out Revision 577aba2fd924bf7b7ade65292de9c44c4d5eb096 (origin/main)
> git config core.sparsecheckout # timeout=10
> git checkout -f 577aba2fd924bf7b7ade65292de9c44c4d5eb096 # timeout=10
> git branch -a -v --no-abbrev # timeout=10
> git checkout -b main 577aba2fd924bf7b7ade65292de9c44c4d5eb096 # timeout=10
Commit message: "Merge pull request #5363 from hzhou/2106_byteorder"
> git rev-list --no-walk b1b700c6f9ec6e59519b211cc74365e6b3220eb2 # timeout=10
[mpich-tarball] $ /bin/bash -xe /tmp/jenkins1852191929035321431.sh
+ umask 0002
+ git config core.abbrev 12
++ uname -m
+ export PATH=/homes/MPI/software/tools/install/x86_64/bin:/homes/jain/anaconda3/bin:/homes/jain/anaconda3/condabin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
+ PATH=/homes/MPI/software/tools/install/x86_64/bin:/homes/jain/anaconda3/bin:/homes/jain/anaconda3/condabin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
+ BASE=/mcs/mpich/downloads/nightly
+ persist_tmp=/mcs/mpich/tmp
+ '[' -d /mcs/mpich/tmp ']'
+ create_snapshot https://raw.githubusercontent.com/pmodels/mpich/main/maint/release.pl http://github.com/pmodels/mpich main main
+ script=https://raw.githubusercontent.com/pmodels/mpich/main/maint/release.pl
+ repo=http://github.com/pmodels/mpich
+ branch=main
+ version=main
+ cd /tmp
+ /mcs/mpich/downloads/nightly/maint/release.pl --git-repo=http://github.com/pmodels/mpich --branch=main --version=main --append-commit-id
Unescaped left brace in regex is deprecated, passed through in regex; marked by <-- HERE in m/\${ <-- HERE ([^ \t=:+{}]+)}/ at /homes/MPI/software/tools/install/x86_64/bin/automake line 3936.
unable to execute (cp -a doc/logging/logging.pdf /tmp/COsryxgM0e/mpich-main-v4.0a2-28-g577aba2/doc/logging), $?=256. Stopped at /mcs/mpich/downloads/nightly/maint/release.pl line 118.
cannot remove path when cwd is /tmp/COsryxgM0e/mpich-main-v4.0a2-28-g577aba2-build for /tmp/COsryxgM0e: at /usr/share/perl/5.22/File/Temp.pm line 778.
Build step 'Execute shell' marked build as failure
1866
Age (days ago)
1866
Last active (days ago)
0 comments
1 participants
participants (1)
sysadmin-notifications@lists.cels.anl.gov
