Re: [allocations-admins] [LCRC Accounts] Project Allocation Request
I exchanged email with Nicole, and suggest we approve her request for 50K in Q3. Ray ----------------------------------------- Ray Bair Argonne National Laboratory On 5/1/17, 3:31 PM, "[email protected] on behalf of [email protected]" <[email protected] on behalf of [email protected]> wrote: Hello, A change in allocation has been requested: Requester: neveu (Nicole Neveu) Project: AWA-beam-dynamics Title: High Accuracy Beam Dynamic Simulations Description: The primary goal of this project is to simulate the two linear electron accelerators at the Argonne Wakefield Accelerator facility. To date, a full 3D models of the beam lines has not been simulated. Using OPAL-T and the parallel capabilities of Blues, we seek better agreement between simulations and experiment by accounting for 3D effects, space charge, coherent synchrotron radiation, and wakefields. Current: undetermined amount Justification: Requested: 50000 A specific reason has been given: Visiting the developers of the beam dynamics simulation code OPAL-T at PSI from May 22nd - May 26th. The goal is to test and run their genetic algorithm code to perform a multi-objective optimization of the AWA beam line. This will require an estimated 5k core-hours per optimization run. We would like to run a few tests while at PSI and several more after returning to ANL in order to prepare results for a paper. This needs to be approved and the final allocation amount decided upon. Thank You, The LCRC Accounts System _______________________________________________ allocations-admins mailing list [email protected] https://lists.lcrc.anl.gov/mailman/listinfo/allocations-admins
participants (1)
Bair, Raymond A.
