[LCRC Accounts] Yearly Allocation Request for DMDOHEMA_1
Hello, A yearly allocation for the LCRC cluster has been requested with the following updated information: Submitter/PI: Baofu Qiao Project Name: DMDOHEMA_1 Division: CSE Project title: Metal Ion Transport through Nano-Structured Lipophilic Systems: Atomistic MD Simulations Associated funding: DOE-BES Other Systems: Science: The interactions and transport mechanisms of metal ions through nano-structured soft matter systems is woefully lacking in fundamental understanding. Such systems are imported in a huge range of applications, such as: extractive separations; forming meso-porous catalytic supports; nano-particle synthesis; life-mimicking systems; etc. Understanding multi-scale structures and interactions is key to developing these important applications and is at the forefront of meso-science. However, soft-matter systems containing coordinating metal ions are notoriously difficult to probe structurally, with the best techniques being synchrotron SAXS and EXAFS giving information on the atomic metal-centric scale and supramolecular scale, respectively. Interpreting such experimental data from these complex systems can give a general idea of coordination environment and the morphology of the supramolecular solvent. However, in order to gain a truly multi-scale understanding with atomi c resolution, we must couple these experimental data with MD simulations, which can be done conveniently and powerfully by directly fitting SAXS and EXAFS data with the simulated systems. This methodology will provide a breakthrough in new fundamental insights into the structural complexity of metal ion – soft matter systems. Project description: In the last one year, large-scale atomistic molecular dynamics (MD) simulations were performed using the LCRC cluster. In the simulations, we were aiming to couple computer simulations with synchrotron X-ray scattering technique to understand the aggregation behaviors of lanthanide metal-bearing systems. These systems root their significant role in the refinery of lanthanide metals using the solvent extraction technique. We have shown the large-scale MD simulations are able to reproduce the X-ray scattering data (e.g., SAXS). Consequently, the experimental structural feature could be inferred from the simulation structures. Moreover, the energetics which drive the metal transport from aqueous phase to organic phase have been explained. We have published two papers, and submitted one paper. We are currently preparing some manuscripts, which will be submitted soon. Detailed discussion have been provided in the progress report. In the coming facial year, we are aiming to study two projects. In the first project, we are planning to study the interfacial behavior of alcohol at water-organic interface. The role of water-organic interface for the metal separations in the solvent extraction process is still unknown to us. In the present project, we are studying a simple model system of alcohol/water/organic biphasic solution. We are aiming to study the surface activity of alcohol molecules at water-organic interface. Alcohol molecular was sometimes used as co-extractant to enhance the transport kinetics of metal from aqueous phase to organic phase. In our preliminary simulations using the classical pairwise CGenFF force field, the aggregation of alcohol was observed to form a monolayer at the water-dodecane biphasic solution. More interestingly, a second layer of alcohol is also observed in some systems, even though it is relatively very weak. This suggests that the alcohols are preorganized into an asy mmetric bilayer at the water-organic interface, which might explain the elevated extraction kinetics of metal transport across the interface. Such an asymmetric bilayer has never been reported to the best of our knowledge. In the coming facial year, we are aiming to run MD simulations using polarizable force field. These polarizable force field simulations will be used to double check the influences of the simulations force field. In these project, polarizable molecular dynamics (MD) simulations will be performed using the Drude force field. Drude force field has been well developed for simple systems as in the present project. We will run the simulations using the NAMD simulation package. The NAMD package supports Drude force field, and scales well up to thousands of CPUs. High impact publications are expected based on the novel finding, and its significance in both the fundamental research and technical application. In the second project, we are aiming to continue our existing project to study the surface feature of metallate (platinum group metal). In collaboration with the SFG experiments led by Dr. Ahmet Uysal (Assistant Chemist at CSE), we are aiming to study the surface aggregation feature of different metallate (i.e, PtCl62- and PdCl42-), and understand their roles of in metallate separation. We have obtained some results. And Some more simulations are planned to complete the project. Some papers are expected when appropriate. Industry partnership: Project URL: Current FY Hours Used: undetermined amount New FY Requested allocation: 100000 Q1: 0 Q2: 0 Q3: 50000 Q4: 50000 Justification: Note that this account (DMDOHEMA_1) was very recently granted 200,000 CPU hours. Therefore, I am not asking for the allocation for the first two quarters. Storage requirements: 1TB storage is large enough for our project. Thank You, The LCRC Accounts System
participants (1)
accounts@lcrc.anl.gov
