Re: [allocations-admins] [LCRC Accounts] Project Allocation Request
Granted 100k. - JB On Thu, Apr 30, 2015 at 3:09 PM, [email protected] <[email protected]> wrote:
Hello,
A change in allocation has been requested:
Requester: sunhwan (Sunhwan Jo) Project: entropy Title: Quantifying protein-protein binding with greatly scalable multiple copy algorithms of NAMD Description: In PMF-based framework, a set of geometric and conformational restraints is applied to the proteins to reduce sampling noise and accelerate the convergence of the resulting free energy profile. These biases are rigorously accounted for to produce the absolute binding free energy. To enhance the PMF convergence, we will combine the umbrella sampling with Hamiltonian and temperature (ℋ and T) replica-exchange molecular dynamics (REM) algorithm. In the US/(ℋ,T)-REMD simulation approach, multiple copies of the molecular systems are simulated concurrently, but all with different conditions, e.g., umbrella potential (Hamiltonians) or temperature. Attempts are periodically made to exchange configurations between different systems using a Metropolis-type Monte Carlo acceptance criterion, insuring Boltzmann-weighted statistics. Such REMD methodology is extremely scalable, yet also very effective to sample a rugged free energy surface.
We anticipate the simulation systems will be comprised of ~50,000 atoms and using at least 255 replicas concurrently. Because of its large size, we plan to use primarily Mira for production and Fusion will be used for initial system preparation and development of enhanced methodology in PMF-based framework. All planned simulations will be carried out by the open-source NAMD molecular dynamics software. The software engine used for the planned simulations is NAMD 2.10 with Charm++ 6.4.0. We have tested t he performance on BG/Q Mira. The scaling of parallel performance was linear up to 512 cores for our test system comprised of 100,000 atoms without using restraint potential and achieved the speed of about 0.025 s/step. Using restraint potential reduces the parallel performance significantly (~0.2 s/step).
The expected number of project member is 3. I, Sunhwan Jo, recently joined LCF as a postdoctoral appointee and will be the main person performing code improvement and algorithm development under the supervision of Wei Jiang (LCF) and Benoit Roux (UChicago).
Current: undetermined amount Justification:
Requested: 350000
A specific reason has been given: We have developed an improved algorithm, which decomposes the total potential energies into different components. This allows more efficient sampling of replicas in temperature space, due to cancellation of solvent-solvent terms with appropriate scaling. We test the performance of the new algorithm and attempt to dissect the entropic contribution from solvent.
This needs to be approved and the final allocation amount decided upon.
Thank You, The LCRC Accounts System
participants (1)
John Blaas
