Re: [allocations-admins] [LCRC Accounts] Project Request: PETSc-Foam
Thanks, Ray. OF 2.2-x needs GCC 4.5.0 and above to work. Also since we are hoping to do some performance monitoring it will be good to run it on Blues initially. We could target some production runs for Fusion at a later time. Dinesh, Jed Brown and Barry from MCS and Prof. Piscaglia from Politecnico di Milano will also be on this project. Shashi ----- Original Message ----- From: "Raymond A. Bair" <[email protected]> To: "LCRC Allocations Admins" <[email protected]>, [email protected] Sent: Friday, September 27, 2013 9:11:02 AM Subject: Re: [allocations-admins] [LCRC Accounts] Project Request: PETSc-Foam Lets grant the 150K for Q1 and Q2. Can this be done on FUsion? Ray ----------------------------------------- Ray Bair Computing, Environment, and Life Sciences Argonne National Laboratory and the University of Chicago TCS Building 240, Room 4122 9700 South Cass Avenue Argonne, IL 60439 email: rbair(at)anl.gov Phone: (630)252-5751 On 9/27/13 7:11 AM, "[email protected]" <[email protected]> wrote:
Hello,
A new project on the LCRC cluster has been requested. Please forward the information on to the LCRC Allocation sub-committee.
Applicant's name: Shashi Aithal Applicant's institution: ANL Applicant's division: CELS Project Name: PETSc-Foam Project title: Investigation of robust, scalable solvers for OpenFoam Associated funding: PETSc Other Systems: Science: OpenFOAM (OF) is a multi-physics open-source solver code capable of modeling a wide-range of problems of interest to various divisions at ANL. One of the strengths of OpenFOAM is that new solvers and utilities can be created by its users. In this project, we intend to investigate fast, robust, scalable solvers for problems involving moving boundaries and combustion. The goal is to study various methodologies for load-balancing and solvers for large-scale simulations. Project description: OF is parallel, finite-volume CFD code. OF version 2.1.0 has been installed and tested on Fusion. Preliminary scaling studies on dsmcFoam and dieselFoam have shown good scalability. Small DSMC cases (1 million cells) have shown good scalability up to 192 cores. DieselFoam has shown good scalability up to 512 cores with about 500K cells. We intend to use OpenFoam 2.2-x as the starting point in our work. Various algorithms for efficient domain decomposition and solution methods for combusting mixtures will be investigated for optimal performance and robustness. The first quarter will focus on compiling, running and testing small problems and studying various methodologies. More detailed cases studies are planned for the second, third and fourth quarters. Project URL: Requested allocation: 350000 Q1: 50000 Q2: 100000 Q3: 100000 Q4: 100000 Justification:
The requester has used undetermined amount hours of their initial startup project.
In addition to approving an initial amount, please specify a Category and Subcategory for this project. For a list of the current selection of approved categories, please see:
https://wiki.lcrc.anl.gov/wiki/Processes/Categories
Once the Allocation committee has approved the project, please go to the Project Management page to create it:
https://accounts.lcrc.anl.gov/projects.php
Thank You, The LCRC Accounts System _______________________________________________ allocations-admins mailing list [email protected] https://lists.lcrc.anl.gov/mailman/listinfo/allocations-admins
participants (1)
Shashi Aithal
