Re: [allocations-admins] Fwd: Re: Negative Allocation Balance
On Mon, Feb 07, 2011 at 05:52:30PM -0600, Bair, Raymond A. wrote:
If people do not use all the advance, do they lose it?
I think the committee had decided yes, although there may be exceptions. In either case, case, I warned Gary that any unused balance might expire at midyear, but he estimated that they would likely use the 100K by then, so that would be OK. John
----- Original Message ----- From: John Valdes [mailto:[email protected]] Sent: Monday, February 07, 2011 05:41 PM To: [email protected] <[email protected]> Subject: Re: [allocations-admins] Fwd: Re: Negative Allocation Balance
Gary was asking to have some of his 2nd half time forwarded for project dynamics. OK to advance 100K?
John
On Thu, Jan 27, 2011 at 06:58:47PM -0600, John Valdes wrote:
Gary Leaf is running low on time on his project "dynamics" and asked (in person) if we could advance 100K to his project. dynamics was initially given 150K, most of which has been used in the past 2 months. Gary said he has more runs to do as does a collaborator, and between them they can probably use up the 100K by midyear. OK to advance the 100K?
John
----- Forwarded message from Gary Leaf <[email protected]> -----
Date: Thu, 27 Jan 2011 14:35:01 -0600 (CST) From: Gary Leaf <[email protected]> To: John Valdes <[email protected]> cc: Gary Leaf <[email protected]> Subject: Re: Negative Allocation Balance
John : What do I need to do in order to obtain some positive balance?
-2414%)./start.x Notice: Project "dynamics" has a negative allocation balance; your job will run at the lowest priority. 508211.fmgt2.lcrc.anl.gov (fusion-2415%)
GKL
----- End forwarded message ----- _______________________________________________ allocations-admins mailing list [email protected] https://lists.lcrc.anl.gov/mailman/listinfo/allocations-admins
participants (1)
John Valdes
