[LCRC Accounts] Project Allocation Request
Hello, A change in allocation has been requested: Requester: asumer (Aslihan Sumer) Project: Multicomp_Nanopart Title: Next Generation of Multicomponent Nanocatalysts: Computational Studies Description: The planned computations will explore the structural (e.g., mixed, core-shell, dumbbell-like, and other), energetic, dynamical/thermal, electronic, and chemical/catalytic properties and characteristics of multicomponent metal nanoparticles, both gas phase and deposited on supports. Among the targeted nanocatalysts are Pt-Co (the work on this system has been initiated already), Pt-Ni, Pt-Fe, CoPt3/Au, FePt/Au, Au/Fe2O3, CoPd2/Au, and others. These are the one currently investigated or planned for investigation by the experiments. The candidate supports include iron-oxide and cobalt-oxide. Among the issues that will be addressed are: 1) Use of size, structure and composition of the nanocatalysts as "knobs" for tuning their activity and selectivity, and 2) Use of functionalizing ligands such as amines of different "sizes" (different lengths of the carbon chains) as an additional means of affecting the catalytic functionality (experiments on the effects of functionalization of various multicomponent nanocatalysts by amines are currently underway). The computational studies of the structural, energetic, and electronic aspects will be performed using density functional theory. The packages that will be utilized include NWChem and Crystal (we have recently purchased the license for Crystal and installed the software on the Fusion cluster). Naturally, we will take full advantage of the parallelized versions of these packages as we intend to explore systems with an ever increasing number of atoms: 1) The properties of the nanocatalysts will be explored over the size r ange from a few tens to a few hundreds of atoms, and 2) The effects of the supports will later be incorporated as well. In addition to the DFT studies, we also plan to perform large scale molecular dynamics simulations of the dynamical and thermal behavior of the multicomponent catalytic nanosytems. The expected number of users on this project is 3 or more. Current: undetermined amount Justification: The allocation request is based on estimates made with NWChem on Fusion and on NERSC (Carver and Hopper) machines. Tests on a a relatively small Pt14 cluster with the new Stuttgart pseudopotential and a basis set of 38 contracted Gaussians per atom with a 2-butyne or 2-butene molecule on it performed with 64, 128 and 192 processors indicate a substantial increase in performance with the increase in the number of processors up to about 128. Tests with Crystal are in progress, however literature data indicates high efficiency of the parallelization of this code. 1) Scalability of NWChem on Fusion as evaluated by us for the C4H6-Pt14 system (total of 736 basis functions and with charge density fitting): Cores Average SCF cycle (s) 64 19.4 128 12.5 192 10.8 2) Scalability of MPP_Crystal on Hector (UK) as evaluated for the Ga432Sb426N6 system (19836 basis functions) [1]: Cores Average SCF cycle (s) 856 2503 1712 1308 3424 711 [1]I. J. Bush et al., Proc. Royal. Soc. 467, 2112 (2011) Requested: 200000 A specific reason has been given: One the issues that is addressed in this project is the relationship between the size of metal nanoparticles and their efficiency in selected model catalytic transformations, which includes the selective hydrogenation of unsaturated aldehydes, for example. The computational studies (within the framework of density functionals) performed to date include nanoparticles ranging from a few atoms to a few tenths of atoms. Our results provide important information on trends in catalytic activity and selectivity at this subnanometer size range. In order to provide a complete picture of the size effect, the ongoing studies have recently been expanded to include nanoparticles of a few hundreds of atoms. The increased complexity of systems at this size (i.e., the larger number of possible adsorption sites to be tested in order to reach the minimum energy adsorption configurations of the reactants on the nanoparticles), along with the computational efficiency requirements that increase in proportion with the number of atoms in the system (our scaling studies showed that maximum efficiency is obtained with 64-128 processors for the systems with approximately 300 atoms that are currently under investigation), make it necessary to request this additional allocation for the current fiscal year. This needs to be approved and the final allocation amount decided upon. Thank You, The LCRC Accounts System
participants (1)
accounts@lcrc.anl.gov
