[LCRC Accounts] Yearly Allocation Request from biodiesel-combustion
Hello, A yearly allocation for the LCRC cluster has been requested with the following updated information: Submitter/PI: Sibendu Som Project Name: biodiesel-combustion Division: ES, CSE Project title: Computation Fluid Dynamics Modeling of Petrodiesel and Biodiesel Associated funding: LDRD Project Other Systems: Convergent Science Inc., FORD Motor Company Science: This project will use an Eulerian-Lagrangian Computation Fluid Dynamics (CFD) software called CONVERGE to model various diesel engine processes like internal nozzle flow, spray behavior, combustion and emission processes. The goal is to capture the differences between diesel and biodiesel fuels from a CFD standpoint since computer based modeling is more cost effective than performing full scale laboratory experiments. Project description: The project is dived in two parts: In the first part, engine processes will be modeled using petrodiesel. The spray data obtained from Advanced Photo Source at Argonne and single-cylinder engine performance and emission data from CAT cell will be used to further develop and validate spray and combustion models in CONVERGE and perform parametric studies. The major motivation is to develop more predictive and robust sub-models for capturing diesel engine processes. In the second part, fundamental studies will be performed to establish flame stabilization and lift-off characteristics of biodiesel using CONVERGE. A new surrogate (consisting of methyl decanoate, methyl 9 decenoate, n-heptane) fuel will be used for modeling the combustion characteristics of biodiesel. Comparison will be performed between inner nozzle flow, non-evaporating and evaporating spray, combustion characteristics, engine performance and emission characteristics of biodiesel and petrod iesel. Biodiesel fuel obtained from different feedstocks such as Soy, Cuphea, Rape-seed will be modeled. Blends of biodiesel with diesel fuel will also be simulated. FORD motor company has requested this surrogate mechanism for performing some internal studies. Based on the feedback from FORD, the mechanism will be further improved for the benefit of the industry. 1) Finite volume schemes 2) RANS turbulence models used 3) Detailed chemical kinetic models for diesel and biodiesel fuels 4) CONVERGE software is being used - ~50 licenses available 5) Scales well up-to 256 processors 6) Detailed spray models used for different spray processes 7) Full cycle engine simulations Project URL: http://www.transportation.anl.gov/engines/multi_dim_model_home.html Current FY Hours Used: undetermined amount New FY Requested allocation: 499000 Q1: 125000 Q2: 125000 Q3: 125000 Q4: 124000 Justification: Thank You, The LCRC Accounts System
participants (1)
accounts@lcrc.anl.gov
