[LCRC Accounts] Project Allocation Request
Hello, A change in allocation has been requested: Requester: svasquez (Silverio Vasquez) Project: ESMF Title: Earth System Modeling Framework Description: The previously released NUOPC Layer reference API was refined to provide a more object-oriented interface that better reflects the NUOPC Driver, Model, Connector, and Mediator concepts. The NUOPC Driver now allows child components to be added dynamically, supporting the implementation of more flexible applications. String labels are consistently used to identify component instances and initialize/run/finalize phases. The introduction of namespaces allows for more control over automatic field pairing, and LocStreams (a geometric type that can be used to represent a set of disconnected points) can now be transferred between components during initialize. The compliance checker has become aware of the component context and produces more useful output. Finally, some of the utility routines previously contained in the NUOPC Layer have moved into ESMF. In the area of ESMF regridding, a new application, ESMF_Regrid, was added. This command-line tool can be used to regrid a data field defined in a UGRID or GRIDSPEC format file to another field defined in a different file. The ESMF_RegridWeightGen application, which precomputes regridding weights, now supports additional options to i) allow non-conservative regridding on cell center locations in the unstructured case, ii) ignore degenerate cells, and iii) choose between different line options when regridding on a sphere. The ESMF regridding implementation now supports an option for using a first order conservative method for unstructured Meshes built on DOE's MOAB mesh library (the version built on ESMF's native mesh library is still available). ESMF unstructured Meshes have been extended to handle elements that consist of more than one polygon to allow the representation of geographically disconnected areas (e.g. the Hawaiian Islands) as a single element. The ESMF regridding capability was further extended to cover i) ESMF LocStreams, ii) first-order conservative regridding of concave quadrilateral cells, iii) non conservative regridding on Mesh elements with more than four sides, and iv) the use of great circle lines when computing 3D bilinear interpolation weights on a sphere. The ESMF Python interface ESMPy has matured and offers more complete coverage of the ESMF Grid, Mesh, and LocStream classes. It also now offers read methods that allow a Field to be filled with data from a NetCDF file. Anaconda packages are now available for easy installation of ESMPy on Linux and Darwin systems. Currently ESMF is regression tested daily on Blues with: -- gfortran with mvapich2, and mpich3 -- intel with mvapich2 and mpich2 -- nag with mpich2, mpich3, and openmpi -- pgi with mvapich2 and mpich3 On the Blues gfortran, benchmark testing is included to detect any unexpected change in the performance of the software. ESMPy is also tested on Blues with mvapich2. ESMPy is the ESMF Python Regridding inteface. ESMPy testing includes building and installing ESMF with NetCDF, building python, running unit tests, examples and regridding from files tests. On Fusion, ESMF is regression tested with: -- g95 with mvapich2 -- gfortran with mvapich2 and mpich2 -- intel mvapich2 mpich2 . The regression test includes: - building the ESMF software and installing it, - building and testing 6 applications, - building and running system tests, examples and unit tests bundled with the software. The entire test suite is run with debug and optimized settings. In addition, two versions of ESMF are regression tested, the head of the development, and a branch based on the last public release where limited development has continued. Current: undetermined amount Justification: Requested: 350000 A specific reason has been given: The ESMF regression tests are running longer than anticipated. This needs to be approved and the final allocation amount decided upon. Thank You, The LCRC Accounts System
participants (1)
accounts@lcrc.anl.gov
