[LCRC Accounts] Yearly Allocation Request for PETSc-Foam
Hello, A yearly allocation for the LCRC cluster has been requested with the following updated information: Submitter/PI: Shashi Aithal Project Name: PETSc-Foam Division: CELS Project title: Investigation of robust, scalable solvers for OpenFoam Associated funding: PETSc Other Systems: Science: OpenFOAM (OF) is a multi-physics open-source solver code capable of modeling a wide-range of problems of interest to various divisions at ANL. One of the strengths of OpenFOAM is that new solvers and utilities can be created by its users. In this project, we intend to investigate fast, robust, scalable solvers for problems involving moving boundaries and combustion. The goal is to study various methodologies for load-balancing and solvers for large-scale simulations. Project description: OF is parallel, finite-volume CFD code which will be used for this project. Scaling studies on dsmcFoam and dieselFoam have shown good scalability. Small DSMC cases (1 million cells) have shown good scalability up to 192 cores. DieselFoam has shown good scalability up to 512 cores with about 500K cells. We intend to use OpenFoam 2.2-x as the computational tool. Various algorithms for efficient domain decomposition and solution methods for combusting mixtures will be investigated for optimal performance and robustness. New mesh-motion strategies, turbulence models and higher resolution studies are planned. It is seen that about 50000 cells/core is required for good linear scaling with OF with the problems we are working on. Typical simulations with about 1.5 million cells take about 1000 core hours. This year we plan to run some larger simulations (about 15 million cells) along with smaller problems to test various mesh-motion strategies and LES models. We anticipate about 15-20 smaller runs (1000 core-hours) and about 1-2 10,000 core-hour jobs/month, totalling about 40,000 core-hours/month or 480000 core-hours/year. Industry partnership: Project URL: Current FY Hours Used: undetermined amount New FY Requested allocation: 480000 Q1: 120000 Q2: 120000 Q3: 120000 Q4: 120000 Justification: Storage requirements: Thank You, The LCRC Accounts System
participants (1)
accounts@lcrc.anl.gov
