[LCRC Accounts] Yearly Allocation Request for SHARP-IF
Hello, A yearly allocation for the LCRC cluster has been requested with the following updated information: Submitter/PI: Rui Hu Project Name: SHARP-IF Division: NE Project title: SHARP – Intermediate Fidelity Modeling Associated funding: DOE-Nuclear Energy Other Systems: Science: An intermediate fidelity (IF) thermal-hydraulics modeling method is being pursued under NEAMS Reactor Product Line (SHARP) for a fast-running, modest-fidelity, whole-core transient analyses capability. The approach is essential for design scoping and engineering analyses and could lead to improvements in the design of the new generations of reactors and to the reduction of uncertainties in safety analysis. The IF method relies on RANS based turbulence modeling approach and advanced system modeling methods to represent the fluid flow and heat transfer physics. Project description: The system analysis code and the RANS-based commercial CFD code STAR-CCM+ are incorporated into the SHARP framework for a multi-scale analysis of Advanced Fast Reactors. In the previous fiscal year, the feasibility of performing coupled System code and STAR-CCM+ simulations of protected loss-of-flow accident was demonstrated. In the planned activities for FY15, this coupling exercise will be extended to couple the system tool with high-fidelity spectral element tool Nek-5000. Accurate predictions of flow and temperature are essential to assure the reactor safety during postulated accidents. In this effort, the core channels will be modeled by Nek5000 and the rest of the primary coolant system and the secondary system were simulated by the SFR Module, and the flow and temperature conditions at the interface were exchanged between the two codes as boundary conditions. Furthermore, the CFD code STAR-CCM+ will be continuously used for design evaluations of reactor systems and experimental facilities. Notably, advanced sodium fast reactor design concept and the natural convection shutdown test facility that is currently being built at Argonne. This type of simulations is essential to assure the safety of the proposed design. Also, the simulation results of the NSTF will be compared against to the experimental results as a validation study of the CFD code. At Argonne, the CFD code STAR-CCM+ are routinely applied to simulations that use more than 100 cores, and good parallel performance has been observed. As problem size increases, i.e. for finer meshes and for large pin bundles, larger numbers of cores would be utilized and based on data from the developers good parallel performance will continue to be expected. On the other hand, the system code, the SFR Module based on MOOSE is a new development. The parallelization will be provided by the underlying MOOSE framework that is built on PETSc. The scalability of MOOSE has been demonstrated by other MOOSE-based applications. The system code usually relies on coarse representation of the system thus does not require significant amount of computing resources. Industry partnership: Project URL: Current FY Hours Used: undetermined amount New FY Requested allocation: 300000 Q1: 60000 Q2: 60000 Q3: 80000 Q4: 100000 Justification: Storage requirements: 1 TB Thank You, The LCRC Accounts System
participants (1)
accounts@lcrc.anl.gov
