Fwd: RE: [lcrc-support #53805] RE: [LCRC Accounts] LCRC Project Created: Metastable_Materials
Weronika is asking for an advance on his project, Metastable_Materials, which is currently -133K in the hole. He requested 475K for the FY and was granted 237.5K (=1/2; not scaled by 80%, likely since it's priority 1, iirc). OK to advance 150K? That will make him positive again, but only leave him with 27K, which I'm guessing he'd use by March. John ----- Forwarded message from "Walkosz, Weronika M." <[email protected]> ----- Date: Thu, 10 Feb 2011 13:55:30 -0600 From: "Walkosz, Weronika M." <[email protected]> To: [email protected] Subject: RE: [lcrc-support #53805] RE: [LCRC Accounts] LCRC Project Created: Metastable_Materials Reply-To: [email protected], "Walkosz, Weronika M." <[email protected]> hello, I ran out of the units (1/2 of them, I suppose) for the project titled Metastable_Materials on fusion. Could I please release the other half of the allocation for me? Thanks, Weronika Walkosz -----Original Message----- From: LCRC Support via RT [mailto:[email protected]] Sent: Thu 9/30/2010 3:39 PM To: Walkosz, Weronika M. Subject: [lcrc-support #53805] RE: [LCRC Accounts] LCRC Project Created: Metastable_Materials Thank you for your email to LCRC Support. This message has been automatically generated in response to your email regarding: RE: [LCRC Accounts] LCRC Project Created: Metastable_Materials which has been assigned ticket #53805. LCRC Support will respond personally to this ticket as soon as possible. In order to help us track the progress of this request, we ask that you please include the string: [lcrc-support #53805] in the subject line of all future correspondence about this issue. You may do this simply by replying to this email. You may find the URLs below helpful when using the LCRC cluster. In fact, the answer to your question might be found therein: http://www.lcrc.anl.gov/jazz/Documentation/NewUserGuide/index.php http://www.lcrc.anl.gov/jazz/Documentation/index.php http://www.lcrc.anl.gov/faq/cache/ Some quick tips: To access LCRC computers, you need to use SSH; see: http://www.lcrc.anl.gov/jazz/Documentation/General/sshkey.php For reference, a copy of your mail has been included below. Thank you, LCRC Support [email protected] ------------------------------------------------------------------------- Thank you. -----Original Message----- From: [email protected] [mailto:[email protected]] Sent: Thu 9/30/2010 3:32 PM To: [email protected] Subject: [LCRC Accounts] LCRC Project Created: Metastable_Materials Weronika Walkosz, Your project was approved by the LCRC Allocations Committee. Project Name: Metastable_Materials Allocation: 237500 Note from the LCRC Allocation Committee: This is your initial allocation for FY11 for fusion. We are granting 1/2 of your request at this time. The remainder of your request will be considered at the midyear Allocation Committee meeting in March. This project may have been approved for a smaller amount than requested prior to the quarterly allocation committee meeting; if this is the case, you will receive mail indicating an allocation increase if the committee approves an additional amount at the next meeting. The project can be administrated from the LCRC Project web page: https://accounts.lcrc.anl.gov/projects.php Use the web page to add members (and remove) members to the project, or to request an additional allocation if your project runs out of time. You can see additional information about your project, including the balance of hours, members and job transactions, by running the "lcrc-qbank" command from the command line on the LCRC cluster. You can also use the lcrc-qbank command to set your default project. For example, to change your default project from startup-joeuser to anl-mcs-support, you would type the following command on any of the login nodes: [joeuser]$ lcrc-qbank -s default anl-mcs-support Previous Default Project: startup-joeuser New Default Project: anl-mcs-support For more information on projects and using the allocation tools refer to the LCRC documentation: http://www.lcrc.anl.gov/jazz/Documentation/ApplicationDocumentation/qbank/ja... Thank You [email protected] ----- End forwarded message -----
participants (1)
John Valdes
