[LCRC Accounts] Yearly Allocation Request from SepMD
Hello, A yearly allocation for the LCRC cluster has been requested with the following updated information: Submitter/PI: Kent E. Wardle Project Name: SepMD Division: CSE Project title: Molecular Dynamics Simulation of Separations Processes Associated funding: DOE-NE Nuclear Energy Advanced Modeling and Simulation (NEAMS) Program Other Systems: MCS Full-disclosure (SiCortex 5832) Science: Liquid-liquid extraction is used in a variety of chemical processes relevant to energy technology and most notably is the primary means for recycle of used nuclear fuel. Computational science-based simulation of such processes can lead to key advancements in fuel recycle technology through increased understanding of the scientific foundations of such physical phenomena. Predictive simulation of a complex process such as liquid-liquid extraction requires accurate representation of the fundamental physics and chemistry on a number of scales ranging from the molecular level to the continuum and engineering scale and covering an equally broad range of temporal scales. This project seeks to develop accurate intermolecular potentials incorporating molecular polarizability for use in molecular dynamics simulations of liquid-liquid interfacial phenomena. Electronic structure calculations for key molecular species of interest will be used to calculate polarizabilities. It is anticipated that physically realistic molecular models as developed here will help to move toward greater predictive capability and ultimately enable the design of advanced extractants for efficient separations processes. Project description: Polarizable potentials will be developed using a Drude oscillator implementation which has recently been incorporated in the NAMD code. While polarizable models have been developed for a number of the required species such as water and alkanes, models for extractant molecules are not available. This project has started by developing a polarizable model for a key extractant for nuclear-related separations process, namely, tributyl phosphate (TBP) using the FY10 project allocation. Additional refinements to this model and the development of other models for other extractants and components relevant to solvent extraction for nuclear fuelt recycling will be done during FY12. As before, this will be done using electronic structure calculations with Gaussian. The requested allocation will enable us to perform rigorous calculations and explore a wider configuration space for each molecular species to be explored. In general, these simulations will use only 8-16 processors but require multiple runs for many tens of hours. Following Gaussian simulations, MD model development and testing will be performed in CHARMM and NAMD. CHARMM will be used primarily for system configuration setup and small-scale testing while NAMD will be used for full-scale simulations. The allocation requested here is primarily for the Gaussian work as we are currently running NAMD very successfully on the SiCortex machine Full-Disclosure in MCS. In addition to the model development work and MD simulations, an additional exploratory effort on application of these molecular models for prediction of phase distribution coefficients using the Gibbs ensemble method as implemented in the MPI-parallel code Towhee will also be performed. This is a small exploratory effort at this point but may grow into a separate project in the future. As this project is still in the startup/exploratory phase, the requested allocation is quite small but increased resources may be required in the future. This project has one PI and perhaps 1-2 additional researchers. Project URL: Current FY Hours Used: undetermined amount New FY Requested allocation: 60000 Justification: Thank You, The LCRC Accounts System
participants (1)
accounts@lcrc.anl.gov
