[LCRC Accounts] Project Allocation Request
Hello, A change in allocation has been requested: Requester: ssom (Sibendu Som) Project: CAT-engine-modeling Title: Detailed Engine modeling using CONVERGE Description: The commercial CFD code, CONVERGE will be used to conduct 3-D diesel engine simulations. Currently, CONVERGE has been run on FUSION on 24 cores. Good scaling has been seen up to 24 cores. The current study aims to increase the computational load using greater resolution, bigger chemistry mechanism and possibly more complicated geometries. Scaling of CONVERGE on a larger number of cores will be studied. It is expected that 3 ANL researchers along with 3 CAT engineers will be using these core hours. Current: undetermined amount Justification: Requested: 250000 A specific reason has been given: A series of large core count (512 and 1024) cases were run to study the scaling issues of CONVERGE with large mechanisms. Several interesting observations were noted about the scalability factors and bottlenecks. A larger suite of runs on smaller number of cores will be conducted in the remaining 3 quarters. Some of these will short runs (1000-5000 core hours) to study scalability issues. Once the number of cores required for good scaling is determined, productions runs will be conducted. This needs to be approved and the final allocation amount decided upon. Thank You, The LCRC Accounts System
participants (1)
accounts@lcrc.anl.gov
