[LCRC Accounts] Project Allocation Request
Hello, A change in allocation has been requested: Requester: ssom (Sibendu Som) Project: spray-modeling Title: Development of a near nozzle spray modeling approach Description: The project is divided into 5 major tasks to be performed in 3 years in collaboration with Convergent Science Inc., and Cummins Engine Company: Task 1: Development and validation of a nozzle flow model to account of transient effects such as needle movement, needle off-axis motion, rail pressure fluctuations etc. Task 2: Further advancement of KH-ACT (Kelvin Helmholtz – Aerodynamic Cavitation Turbulence) primary breakup model to calculate more accurately relevant length and time-scales for the cavitation, turbulence, and aerodynamically induced breakup processes. Task 3: In the past nozzle flow and spray simulations have been statically coupled. A dynamic coupling approach will be developed so that the nozzle flow simulations can influence the spray development and vice versa. This is quite complicated since the length and time scales associated with nozzle flow processes are significantly different from spray processes. Task 4: An one equation non-viscosity dynamic structure model large eddy simulation (LES) based turbulence modeling approach will be implemented in CONVERGE. Grid-convergence on critical spray parameters will be evaluated with the implemented LES models. Task 5: Implementation of an Eulerian-Lagrangian spray model: While dynamic coupling of the nozzle flow and KH-ACT models will enhance the accuracy of spray simulations, a transition between the Eulerian and Lagrangian phases must take place at the nozzle exit with this approach. Moving the transition point downstream allows for a more natural bridge between the coupled simulations as the liquid fuel is modeled in an Eulerian framework on both sides of the nozzle exit. A specific challenge of this task is developing an algorithm to convert the Eulerian liquid to Lagrangian parcels outside of the dense spray region. Current: undetermined amount Justification: Requested: 100000 A specific reason has been given: The allocated time was lower than the original request during the committee meeting. Also new personal have joined the group and performing simulations which has increased the need for more core hours. This needs to be approved and the final allocation amount decided upon. Thank You, The LCRC Accounts System
participants (1)
accounts@lcrc.anl.gov
