Re: [AG-TECH] Node Service Fails
Hi Greg: Since you say that the node has worked fine 'for about a year now', I suspect a problem with your certificate, which has a validity of one year. If you look in the logfiles (VenueClient.log and ServiceManager.log, on the display and other machines, respectively), you may see an explicit indication of this. (Logfiles are in %APPDATA%\AccessGrid\Logs on Windows, and in ~/.AccessGrid/Logs on Linux.) With the 2.4 release, you would receive a warning regarding an expired or about-to-expire certificate each time you start one of the components of the software. If this isn't the problem, you can send the logs (to ag-info) and we'll try to help. Tom Uram On 10/20/05 5:57 PM, Gregory Browning wrote:
Hello all,
I am having a problem that is driving me crazy. Here is my setup:
3 machines, 1 windows xp (display), 2 Fedora core 3 (video and audio) running AGTK 2.3.
Ok, We have had this setup for about a year now and everything has worked ok until a month ago.
Here is what I do to start my access grid.
Start agservicemanager.py on the video machine. (starts no problem)
Start agservicemanager.py on the audio machine. (starts no problem)
Start the node service on the display machine. (errors out)
Here is the error:
/Starting Node Service URL: https://144.167.32.101:11000/NodeService/
/Starting Service Manager URL: https://144.167.32.101:11000/ServiceManager/
/Traceback (most recent call last):/
/ File "C:\Program Files\AGTk-2.3\bin\AGServiceManager.py", line 145, in ?/
/ main()/
/ File "C:\Program Files\AGTk-2.3\bin\AGServiceManager.py", line 130, in main/
/ gNodeService.LoadDefaultConfig()/
/ File "C:\Python23\Lib\site-packages\AccessGrid\AGNodeService.py", line 359, in/
/ LoadDefaultConfig/
/ raise Exception("Failed to load default configuration <%s>" %/
/Exception: Failed to load default configuration <FINAL1>/
I have no firewalls on.
The time is sync (does the time have to be perfectly synced?)
Anybody have a clue? Please help
Greg Browning
<http://cybercollege.ualr.edu/syseng/systemhome.html>
UALR Systems Engineering <http://cybercollege.ualr.edu/syseng/systemhome.html>
*Gregory W. Browning** MCSE, MCSA, NETWORK+, A+* /Laboratory Specialist/
*University** of **Arkansas** at **Little Rock* 2801 South University Avenue Systems Engineering ETAS 300M Little Rock, Ar 72204 <http://maps.yahoo.com/py/maps.py?Pyt=Tmap&addr=2801+South+University+Avenue&csz=Little+Rock%2C+Ar+72204&country=us>
[email protected] <mailto:[email protected]>
tel: tel2: fax:
501-683-7101 501-569-3100 501-569-8698
/Add me to your address book.../ <https://www.plaxo.com/add_me?u=8590454154&v0=1024727&k0=853813787>
/Want a signature like this?/ <http://www.plaxo.com/signature>
participants (1)
Thomas D. Uram
