RE: [AG-TECH] Access Grid 3.1 beta1 Release Available
Hi, Try something like "C:\PROGRA~1\" instead of "C:\Program Files\". It usually helps in case of problems concerning with spaces in the path and old parsers. Since MSDOS names should have only 8 chars long, at maximum, and no spaces or special chars. So, if you have a directory with more than 8 chars, you can use an abbreviation of it using the first 6 and adding '~1' at the end. If you have more than one directory starting with the same first 6 chars, '~2' and '~3' can be used. I believe that this notation can also be used for file names. Best regards, Ant�nio Bandeira FEUP :: SICC ~ uTICM +351 225 574 199 (ext.3535) [email protected] -----Original Message----- From: [email protected] [mailto:[email protected]] On Behalf Of Andrew A Rowley Sent: 04 July 2007 12:00 To: Thomas D. Uram; ag-tech Subject: RE: [AG-TECH] Access Grid 3.1 beta1 Release Available Hi, I am still getting the same issue with this that I was having with all versions since 3. The audio and video services do not start when I enter a venue. Attached are my log files of the services. I believe that the problem is to do with the fact that there are spaces in the path to the executable (at least if I put the executable in inverted commas, it goes away). This does not appear to affect everyone, but I have seen it happen on systems other than mine, so I don't think this is an isolated issue. Andrew :) ============================================ Access Grid Support Centre, RSS Group, Manchester Computing, Kilburn Building, University of Manchester, Oxford Road, Manchester, M13 9PL, UK Tel: +44(0)161-275 0685 Email: [email protected]
-----Original Message----- From: [email protected] [mailto:[email protected]] On Behalf Of Thomas D. Uram Sent: 29 June 2007 21:45 To: ag-tech Subject: [AG-TECH] Access Grid 3.1 beta1 Release Available
The Access Grid 3.1 beta1 software is available for download at:
http://www.mcs.anl.gov/fl/research/accessgrid/software/releases/3.1-be ta1
This beta release includes new functionality and numerous bug fixes.
3.1 (beta1) Changes
* Inclusion of media tools from Sumover project * Venue Client startup time significantly reduced * Improved bridging support o VenueClient displays full list of bridges (instead of limiting list to ten) o Maintains bridge cache in the background o User preferences for whether and how often to order bridges by proximity; for refreshing the bridge cache manually; and, for user-specified bridge ordering o Support for multiple bridge registries * Supports organization of Venue data into folders o Users can create folders for organizing Venue data * Displays timestamps in Jabber chat * Support for SharedPresentation on Mac * Support for user-specified multicast group for multicast connectivity detection * Certificate-based Venue access control o Includes required client-side proxy certificate support * Plugin support o New extensibility mechanism allows integration of client-side applications
For full information on this release, and a complete listing of the bugs fixed, see the official release page (url above).
As always, user feedback is welcome. Please file feature requests, bug reports, and enhancement requests via the Access Grid Bugzilla page at http://bugzilla.mcs.anl.gov/accessgrid.
Thanks to everyone involved for their hard work.
The AG Developers
participants (1)
Antonio Bandeira
