Re: [AG-TECH] wxPython 2.6 with AG2.4
Hi Fred, On Fri, 2006-04-21 at 10:08 -0500, Fred Dech wrote:
Since yesterday, I've been wondering what the incompatibility is between wxPython 2.5 and AG3.0b2. I've had AG2.4 and AG3.0b2 installed on the same WinXP node for some time with no problems.
wxPython 2.5 is from the unstable wxPython release series, see: http://wiki.wxpython.org/index.cgi/ReleaseSeries so effectively the latest wxPython 2.5.x is a pre-release of the stable wxPython 2.6.0.
As was posted a while back, wxPython 2.6 isn't completely compatible with AG2.4. I'd not run into this first hand until we were doing some shared-app tests yesterday and, as was posted, the Win Shared Web Browser (IE) did not work for AG2.4 with wxPython2.6. The browser works fine with AG3.0b2/wxPython2.6. It also works fine for both AG2.4 and AG3.0b2 with wxPython2.5.
The change happened sometime in the wxPython 2.5.x series, you are most likely using a earlier version of wxPython 2.5 which supports both wx.iewin and wx.lib.iewin modules. See the "SharedBrowser broken with wxPython 2.6" bugzilla report: http://bugzilla.mcs.anl.gov/accessgrid/show_bug.cgi?id=1450 Doug
participants (1)
Douglas Kosovic
