Re: [AG-TECH] Problem with BridgeServer
I suspect that the bridge server is advertising itself using the internal IP. When external clients try to use the bridge, what address/hostname appears in RAT? If this is the problem, you can control the IP address used by the BridgeServer (and other AG components) by setting the GLOBUS_HOSTNAME environment variable to the desired address/hostname. Tom On 2/27/06 9:29 AM, Sebastian Tabarce wrote:
Hello!
I have the folowing setup for an AG Venue Server and an AG Bridge Server: - the Venue Server: one machine running Fedora Core 4 and AGTK 2.4. This machine has the internal IP 192.168.103.55 and the domain name silicon.fe.up.pt. This machine has linked to it the real IP address 193.136.28.183. I don't know exactly what this means in terms of networking, I just asked my network admin to make my machine visible to the Internet and he told me that my machine can be seen from the Internet with this address and also by its name silicon.fe.up.pt. Ports 8000, 8002, 8004, 8006 TCP are opened for this machine. - the Bridge Server is running Slackware 10 and AGTK 2.4. Same as above, internal IP is 192.168.103.62, external IP is 192.136.28.184. and name poly.fe.up.pt. Ports 50000-50010 UDP are opened.
I've conducted some tests. On the internal network everything works fine. From outside, people can connect to my Venue Server using https://silicon.fe.up.pt:8000/Venues/default , they see the BridgeServer and can choose Unicast, however they do not appear in my RAT window and, of course, I cannot talk to them. Multicast is not an option. Also no output in the terminal of the BridgeServer for machines trying to connect from outside. For those on the local network I have the normal output.
Any thoughts about why the Bridge Server is not doing its job?
Thanks, Sebastian
participants (1)
Thomas D. Uram
