Re: [AG-TECH] Video capture card Advice request
12 May
12 May
'09
3:32 a.m.
Hi Khanh,
We are looking to replace the 4-cameras inputs IEI-IVC 200 cards. They are running well on the windows XP machine. However, they gave poor quality on the Fedora 10 system. Even worse, we must configure the video to transmit PAL signal (using H.261) every time we start Access Grid.
I suspect you haven't configured the Video Producer Service to use PAL and saved the configuration. Or maybe you are setting it to PAL directly in VIC, which it'll forget the next time VIC is started. See the following on how to configure a Video Producer: http://www.accessgrid.org/node/1770 you might also like to increase the bandwidth and quality sliders to see if that makes any difference. Cheers, Doug
6313
Age (days ago)
6313
Last active (days ago)
0 comments
1 participants
participants (1)
Douglas Kosovic
