RE: [AG-TECH] Error occurred during certificate import
Hey, A friend of mine had the same problem. We tried deleting the certrepo directory and importing again. I was then told the key was not with the certificate. We then tried to request another certificate 4-5 days ago. We have not gotten it yet. On another note, is it the case that any certificate works? I have a DOE science grid certificate I have been wondering about. Cheers, Tameka -----Original Message----- From: Robert Olson [mailto:[email protected]] Sent: Friday, January 30, 2004 4:52 PM To: [email protected]; [email protected] Subject: Re: [AG-TECH] Error occurred during certificate import If you send me your client logfile: \Documents and Settings\<user>\Application Data\AccessGrid\venueclient.log I'll take a look and see what I can see. If you moved things around in the certRepo dir you've likely caused problems, yes. If you did that, remove the certREpo dir and try the import again. --bob At 02:36 PM 1/30/2004, Darin Oman wrote: I get this error when I try to import a certificate on a Windows machine. The cert has been exported from Linux. I tried moving various certs and .pem files around, so I probably screwed things up even worse, but I still get the same error. Any ideas? Thanks, Darin
participants (1)
Carter, Tameka
