Re: [JLSE-Admins] [JLSE-Users] Haswell-EP E5-2699v3 Nodes Available
Hi Ray, We should be able to accommodate this. Please request a new JLSE resource via http://press3.mcs.anl.gov/jlse/projects/project-request-form/. Under Resources/Test Bed Needed, "Upgrade existing E5-2603v3 JLSE machine "snell" with E5-2620v3 CPUs add four more DIMMs to fully populate memory channels, cost will be $1610.52 via MNJ Tech in AMOS." I also suggest looking into the E5-2650L. It's actually the best flops/watt CPU in the entire line-up. Albeit it is quite a bit more expensive than the E5-2620v3. If your applications are memory bandwidth bound, I'd look at models that support DDR4-2133. Lastly, I'm not sure what vendor or what level/type of hardware you're looking for, but Intel has a really nice 4 node in 2RU system: http://www.intel.com/content/www/us/en/motherboards/server-motherboards/serv.... Thanks, Ben
On Jan 19, 2015, at 10:45 AM, Bair, Raymond A. <[email protected]> wrote:
P.S. The aim is to determine the best price-performance for a 60-node addition to Blues for reactor research.
On 1/19/15, 10:38 AM, "Bair, Raymond A." <[email protected]> wrote:
We would like to compare the 6-core Haswell against our 8-core Sandy Bridge for a floating-point intensive benchmark.
Ray
On 1/19/15, 10:34 AM, "Allen, Benjamin S." <[email protected]> wrote:
Hi Ray,
Not specifically the E5-2620v3. JLSE has one machine with 2x E5-2603v3 (6c, lower clock rate, and lower memory bandwidth), and 8 machines with 2x E5-2699v3. What are you trying to test with the E5-2620v3?
If needed we could upgrade the machine that has the E5-2603v3 CPUs to E5-2620v3. Cost would be $843.72.
Note, I'm pretty sure all 4-8 core Haswell-EP CPUs have a single memory controller.
Ben
On Jan 19, 2015, at 10:03 AM, Bair, Raymond A. <[email protected]> wrote:
Hi Ben,
Does anyone here have the 2620v3 Haswell with 6 cores and 1 memory controller on chip?
Ray
----------------------------------------- Ray Bair Computing, Environment, and Life Sciences Argonne National Laboratory and the University of Chicago TCS Building 240, Room 4122 9700 South Cass Avenue Argonne, IL 60439 email: rbair(at)anl.gov Phone: (630)252-5751
On 12/12/14, 2:18 PM, "Allen, Benjamin S." <[email protected]> wrote:
All,
We've added six systems that each have two Intel Haswell-EP 18c E5-2699v3 CPUs. These CPUs are interesting as they are the first Xeon based system that has greater than a teraflop of performance.
Hostnames: thing{00,01,04,05,06,07}.ftm.alcf.anl.gov
- SuperMicro SC747BTQ-R1K62B 1600W 4RU Chassis - SuperMicro X10DRi Motherboard - 2x Intel Xeon E5-2699v3 18c CPU - RHEL7 (3.10.0-123.6.3.el7.x86_64)
Note, currently these machines do not have an IB connection. We're hoping Mellanox will loan us new EDR hardware for these nodes.
We're waiting on a replacement for a failed CPU on "thing02", and Kaz has "thing03" in Tinkerlab.
Let me know if you run into any issues.
Ben _______________________________________________ Users mailing list [email protected] https://lists.jlse.anl.gov/mailman/listinfo/users
participants (1)
Allen, Benjamin S.
