Re: [JLSE-Admins] JLSE Account Activated
Hi Sameer, Looks like we actually do have 13.1 installed, so I'll need to look into purchasing a license for XLC and XLF. I don't expect to be able to turn this around very quickly unfortunately. Ben On Sep 4, 2014, at 5:32 PM, Allen, Benjamin S. <[email protected]> wrote:
Hi Sameer,
We don't have a paid for license for XL compilers on Dowd unfortunately. It does appear 13.1 (13.0 is installed currently), so I can try to install a new trial version. I should have time todo this tomorrow.
Ben
On Sep 4, 2014, at 4:41 PM, Sameer Shende <[email protected]> wrote:
Hi Ben, I would like to request installation of a new license for the IBM XLC compiler on dowd. I get an error: xlC -O2 -I../inc -c pdbRead.cc The license for the Evaluation version of IBM XL C/C++ for Linux, V13.0 compiler product has expired. Please send an email to [email protected] for more information. The evaluation license can be extended to 74 days in total by either a) setting an environment variable XLC_EXTEND_EVAL=yes; or, b) specifying a compiler command line option -qxflag=extend_eval. The extended evaluation license will expire on Fri Sep 12 22:52:04 2014. Use of the Program continues to be subject to the terms and conditions of the International License Agreement for Evaluation of Programs, including the accompanying License Information document (the "Agreement"). A copy of the Agreement can be found in the "LicenseAgreement.EVAL.pdf" and "license.EVAL.pdf" files residing in the root directory of the installation media. If you do not agree to the terms and conditions of the Agreement, you may not use or access the Program. The evaluation version can be easily upgraded to the full, licensed ve rsion after purchase. Please refer to section "Before installing IBM XL C/C++ for Linux, V13.0" in the Installation Guide.
Thanks, - Sameer
On Sep 3, 2014, at 3:36 PM, Sameer Shende <[email protected]> wrote:
Hi Ben, Thanks! I can compile TAU properly on Dancelot now. It is installed in /soft/perftools/tau/tau_latest like it is on other systems. It includes OMPT configurations for instrumenting OpenMP programs using Intel compilers with TAU. The architecture specific files are located in the TAU x86_64 and mic_linux/lib and bin subdirectories. I look forward to trying TAU on the ARM64 system when it is installed. Thanks, - Sameer
On Sep 3, 2014, at 8:31 AM, Allen, Benjamin S. <[email protected]> wrote:
Hi Sameer,
You need to point to our new Intel license server:
export INTEL_LICENSE_FILE=28518@ftsn2
I do not have a ARM64 server quite yet. We have two APM X-Gene based boards on order from SoftIron: http://www.softiron.co.uk/products/. They should arrive in 20-40 days.
Ben
On Sep 3, 2014, at 9:49 AM, Sameer Shende <[email protected]> wrote:
Hi Ben, Thanks for the info below. I had some problem using the Intel licenses. Do I have to do something special (besides source'ing the compilerenv.sh file) to get it to work on Dancelot? I see: [sameer@dancelot tau-2.23.2b2]$ which icpc /soft/compilers/intel/composer_xe_2013_sp1.3.174/bin/intel64/icpc [sameer@dancelot tau-2.23.2b2]$ icpc -v
Error: A license for CCompL is not available (-76,61026,2).
License file(s) used were (in this order): 1. Trusted Storage ** 2. /soft/compilers/intel/composer_xe_2013_sp1.3.174/licenses ** 3. /opt/intel/licenses ** 4. /home/sameer/intel/licenses ** 5. /soft/compilers/intel/composer_xe_2013_sp1.3.174/Licenses ** 6. /Users/Shared/Library/Application Support/Intel/Licenses ** 7. /soft/compilers/intel/composer_xe_2013_sp1.3.174/bin/intel64/*.lic
Please visit http://software.intel.com/sites/support/ if you require technical assistance.
icpc: error #10052: could not checkout FLEXlm license
Do you have an ARM 64 bit system that I may port TAU to? Thanks! - Sameer
On Aug 27, 2014, at 2:54 PM, Allen, Benjamin S. <[email protected]> wrote:
Would you please make me a directory: mkdir /soft/perftools mkdir /soft/perftools/tau chown sameer /soft/perftools/tau
on dancelot/prancelot, Dowd, Maud/Neddy, Jenny/Ruth/Lucie, Slashing/Clipping/Hooking?
Done.
Note, /soft is shared across like platform machines (i.e. x86_64, ppc64, armv7l).
I can't login to Kayla. Would you please enable my access?
I need to update this machine's configuration, give me a week or so for this.
I can't find modules or soft environment or MPI libraries on Dowd. Where are they located?
We don't have softenv or similar setup in JLSE. It was decided early on that typical users in JLSE would be capable of figuring out their own environments. There's a few installs of mpich in /soft/libraries/mpi on the x86_64 /soft. Note the mpich-intel install is statically compiled and overly optimized, so it's probably not the best for general use.
I don't think anyone has done the same for ppc64. If you'd like to install mpich or similar let me know.
Just a quick note, JLSE resources aren't scheduled, so please be courteous of other users. The Xeon Phi servers are the busiest currently.
Ben
On Aug 27, 2014, at 4:22 PM, Sameer Shende <[email protected]> wrote:
Hi, Would you please make me a directory: mkdir /soft/perftools mkdir /soft/perftools/tau chown sameer /soft/perftools/tau
on dancelot/prancelot, Dowd, Maud/Neddy, Jenny/Ruth/Lucie, Slashing/Clipping/Hooking? Also, I can't login to Kayla. Would you please enable my access? I can't find modules or soft environment or MPI libraries on Dowd. Where are they located? I have installed TAU in my home directory in ~sameer/tau2 on Dowd. Thanks! - Sameer
On Aug 27, 2014, at 2:03 PM, [email protected] wrote:
Hello SAMEER SHENDE,
Your JLSE account, sameer has been activated.
Thank You JLSE Account System
_______________________________________________ Admins mailing list [email protected] https://lists.jlse.anl.gov/mailman/listinfo/admins
participants (1)
Allen, Benjamin S.
