Re: [JLSE-Admins] authentication failure
Hi Ben, I tried but I still can't login. I am using my pin + RSA secureid passcode to login. I hope this is the correct way to login. Thanks, - Sameer On Aug 25, 2014, at 10:10 AM, Allen, Benjamin S. <[email protected]> wrote:
Hi Sameer,
Can you try again in about 15-20 minutes. ALCF is doing network maintenance that's likely effecting JLSE.
Ben
On Aug 25, 2014, at 11:36 AM, Sameer Shende <[email protected]> wrote:
Hi, I am trying to login to JLSE systems and I get: % ssh login.jlse.anl.gov The authenticity of host 'login.jlse.anl.gov (140.221.69.21)' can't be established. RSA key fingerprint is 1e:9e:d7:15:9c:7f:8d:5a:c6:4f:9e:45:bf:17:3a:7c. Are you sure you want to continue connecting (yes/no)? yes Warning: Permanently added 'login.jlse.anl.gov,140.221.69.21' (RSA) to the list of known hosts. Saving password to keychain failed Identity added: /Users/sameer/.ssh/id_rsa (/Users/sameer/.ssh/id_rsa) --------------------------------------------------------------------------- Notice to Users
This is a Federal computer system and is the property of the United States Government. It is for authorized use only. Users (authorized or unauthorized) have no explicit or implicit expectation of privacy.
Any or all uses of this system and all files on this system may be intercepted, monitored, recorded, copied, audited, inspected, and disclosed to authorized site, Department of Energy, and law enforcement personnel, as well as authorized officials of other agencies, both domestic and foreign. By using this system, the user consents to such interception, monitoring, recording, copying, auditing, inspection, and disclosure at the discretion of authorized site or Department of Energy personnel.
Unauthorized or improper use of this system may result in administrative disciplinary action and civil and criminal penalties. By continuing to use this system you indicate your awareness of and consent to these terms and conditions of use. LOG OFF IMMEDIATELY if you do not agree to the conditions stated in this warning.
---------------------------------------------------------------------------- Password:
Received disconnect from 140.221.69.21: 2: Too many authentication failures for sameer
Would you please reset this? Thanks! - Sameer
_______________________________________________ Admins mailing list [email protected] https://lists.jlse.anl.gov/mailman/listinfo/admins
participants (1)
Sameer Shende
