Re: [JLSE-Admins] JLSE Account Activated
Hi Ben, Thanks for the info below. I had some problem using the Intel licenses. Do I have to do something special (besides source'ing the compilerenv.sh file) to get it to work on Dancelot? I see: [sameer@dancelot tau-2.23.2b2]$ which icpc /soft/compilers/intel/composer_xe_2013_sp1.3.174/bin/intel64/icpc [sameer@dancelot tau-2.23.2b2]$ icpc -v Error: A license for CCompL is not available (-76,61026,2). License file(s) used were (in this order): 1. Trusted Storage ** 2. /soft/compilers/intel/composer_xe_2013_sp1.3.174/licenses ** 3. /opt/intel/licenses ** 4. /home/sameer/intel/licenses ** 5. /soft/compilers/intel/composer_xe_2013_sp1.3.174/Licenses ** 6. /Users/Shared/Library/Application Support/Intel/Licenses ** 7. /soft/compilers/intel/composer_xe_2013_sp1.3.174/bin/intel64/*.lic Please visit http://software.intel.com/sites/support/ if you require technical assistance. icpc: error #10052: could not checkout FLEXlm license Do you have an ARM 64 bit system that I may port TAU to? Thanks! - Sameer On Aug 27, 2014, at 2:54 PM, Allen, Benjamin S. <[email protected]> wrote:
Would you please make me a directory: mkdir /soft/perftools mkdir /soft/perftools/tau chown sameer /soft/perftools/tau
on dancelot/prancelot, Dowd, Maud/Neddy, Jenny/Ruth/Lucie, Slashing/Clipping/Hooking?
Done.
Note, /soft is shared across like platform machines (i.e. x86_64, ppc64, armv7l).
I can't login to Kayla. Would you please enable my access?
I need to update this machine's configuration, give me a week or so for this.
I can't find modules or soft environment or MPI libraries on Dowd. Where are they located?
We don't have softenv or similar setup in JLSE. It was decided early on that typical users in JLSE would be capable of figuring out their own environments. There's a few installs of mpich in /soft/libraries/mpi on the x86_64 /soft. Note the mpich-intel install is statically compiled and overly optimized, so it's probably not the best for general use.
I don't think anyone has done the same for ppc64. If you'd like to install mpich or similar let me know.
Just a quick note, JLSE resources aren't scheduled, so please be courteous of other users. The Xeon Phi servers are the busiest currently.
Ben
On Aug 27, 2014, at 4:22 PM, Sameer Shende <[email protected]> wrote:
Hi, Would you please make me a directory: mkdir /soft/perftools mkdir /soft/perftools/tau chown sameer /soft/perftools/tau
on dancelot/prancelot, Dowd, Maud/Neddy, Jenny/Ruth/Lucie, Slashing/Clipping/Hooking? Also, I can't login to Kayla. Would you please enable my access? I can't find modules or soft environment or MPI libraries on Dowd. Where are they located? I have installed TAU in my home directory in ~sameer/tau2 on Dowd. Thanks! - Sameer
On Aug 27, 2014, at 2:03 PM, [email protected] wrote:
Hello SAMEER SHENDE,
Your JLSE account, sameer has been activated.
Thank You JLSE Account System
_______________________________________________ Admins mailing list [email protected] https://lists.jlse.anl.gov/mailman/listinfo/admins
participants (1)
Sameer Shende
