[JLSE-Admins] Unable to build on future tech cluster - license not available
Hi, It has been couple of months since I last tried this, but after setting the environment in my bash_profile as mentioned in https://collab.mcs.anl.gov/display/FT/Future+Tech+Home I get a "A license for CCompL is not available" error when trying to build a simple C program on the jlse login nodes (ftlogin*). What am I doing wrong? =========================== [jayesh@ftlogin1]bash$:~/software/esmf/u-krishna-jayesh-esmf$ icpc hello.c Error: A license for CCompL is not available (-76,61026,2). License file(s) used were (in this order): 1. Trusted Storage ** 2. /soft/compilers/intel/licenses/*.lic ** 3. /soft/compilers/intel/composer_xe_2013_sp1.1.106/licenses ** 4. /opt/intel/licenses ** 5. /home/jayesh/intel/licenses ** 6. /soft/compilers/intel/composer_xe_2013_sp1.1.106/Licenses ** 7. /Users/Shared/Library/Application Support/Intel/Licenses ** 8. /soft/compilers/intel/composer_xe_2013_sp1.1.106/bin/intel64/*.lic Please visit http://software.intel.com/sites/support/ if you require technical assistance. icpc: error #10052: could not checkout FLEXlm license ================================= ============ My bash_profile ============ # .bash_profile # Get the aliases and functions if [ -f ~/.bashrc ]; then . ~/.bashrc fi # User specific environment and startup programs PATH=/home/jayesh/software/autotools/install/bin:$PATH PATH=$PATH:$HOME/bin export PATH export INTEL_LICENSE_FILE=/soft/compilers/intel/licenses #export INTEL_LICENSE_FILE=/soft/compilers/intel/composer_xe_2013_sp1.1.106/uninstall/licenses #source /soft/compilers/intel/bin/compilervars.sh intel64 source /soft/compilers/intel/composer_xe_2013_sp1.1.106/bin/compilervars.sh intel64 source /soft/compilers/intel/vtune_amplifier_xe/amplxe-vars.sh source /soft/compilers/intel/advisor_xe/advixe-vars.sh source /soft/compilers/intel/inspector_xe/inspxe-vars.sh source /soft/compilers/intel/impi/4.1.3.048/bin64/mpivars.sh #export SINK_LD_LIBRARY_PATH=/soft/compilers/intel/composerxe/lib/mic:/usr/linux-k1om-4.7/x86_64-k1om-linux/lib64:/usr/lib64:/opt/intel/opencl/lib64 export SINK_LD_LIBRARY_PATH=/soft/compilers/intel/composer_xe_2013_sp1.1.106/compiler/lib/mic:/usr/linux-k1om-4.7/x86_64-k1om-linux/lib64:/usr/lib64:/opt/intel/opencl/lib64 #PATH=$PATH:/soft/compilers/intel/mic/bin:/usr/linux-k1om-4.7/bin/ PATH=$PATH:/usr/linux-k1om-4.7/bin/ export PATH export OFFLOAD_REPORT=2 =================================== Regards, jayesh
participants (1)
Krishna, Jayesh
