Re: [JLSE-Admins] JLSE MIC home directory
I have little to no experience with VTune. However looking at the screen cap the kernel modules referenced can be found on the MIC at: /lib/modules/2.6.38.8+mpss3.4.2/extra/vnet/intel_micveth.ko /sep3.15/sep3_15-k1om-2.6.38.8+mpss3.4.2smp.ko If I'd have to guess, the debugging symbols are missing because I don't have any of the k1om debug packages installed on the MICs themselves, i.e. "dbg" RPMs from http://registrationcenter.intel.com/irc_nas/5017/mpss-3.4.2-k1om.tar. I try to keep the packages installed directly on the MICs to a minimum as they appear to sit in a RAM disk. Perhaps try running with CLI version of Vtune, amplxe-cl to see if it outputs anymore useful information? Example: export INTEL_LICENSE_FILE=28518@ftsn2 source /soft/compilers/intel/vtune_amplifier_xe/amplxe-vars.sh amplxe-cl -collect advanced-hotspots -target-system=mic-native ls -CF /usr/bin Ben
On Jan 7, 2015, at 1:07 PM, John Tramm <[email protected]> wrote:
Ben,
Thanks for re-deploying - it definitely seems to have helped. I'm now able to run the vtune GUI.
However, now I'm running into a new issue. When I run vtune from the host, in order to analyze an app run on the device, it doesn't appear to be launching successfully (i.e., nothing is output to the terminal, and the resulting vtune analysis says the code only ran for a fraction of a second, when it should be at least several seconds on the MIC).
It also outputs this set of errors when running my project:
<Screen Shot 2015-01-07 at 12.56.50 PM.png>
Can you think of anything that might cause this?
Thanks again so much for your help!
-John Tramm
On Wed, Jan 7, 2015 at 12:47 PM, Allen, Benjamin S. <[email protected]> wrote: Hi John,
The RHEL6 image was missing libXxf86vm, I've re-deployed the three servers (Ruth, Lucie, Jenny) with libXxf86vm installed. I've also updated "sep", which is the sampling kernel module for both the MIC and the host. I doesn't look like Intel included the Power sampling kernel module with Vtune Amplifier XE 2015 however, ie. /soft/compilers/intel/vtune_amplifier_xe_2013/powerdk/src.
Let me know if you run into any more problems.
Ben
On Jan 6, 2015, at 2:50 PM, John Tramm <[email protected]> wrote:
Ben,
I'm trying to use vtune to analyze performance of my application on the mic. I can't seem to get Vtune to run on the host node (either lucie or jenny). I keep getting the following error:
amplxe-gui: error while loading shared libraries: libXxf86vm.so.1: cannot open shared object file: No such file or directory
There seems to be a shared library file missing somewhere that I can't seem to find. Perhaps I need to add something to my linker path?
Thanks for your help!
-John
On Tue, Jan 6, 2015 at 10:35 AM, John Tramm <[email protected]> wrote: Allen,
Yes, everything seems to be working great now. Thanks!
-John
On Mon, Jan 5, 2015 at 2:26 PM, Allen, Benjamin S. <[email protected]> wrote: Hi John,
This should be fixed. Let me know if you run into further issues.
Ben
On Jan 5, 2015, at 11:53 AM, John Tramm <[email protected]> wrote:
Greetings,
I'm trying to use the JLSE MIC nodes, but I can't seem to get my home directory to show up on mic0 itself. It is available on the host, but it doesn't seem to be able to connect on the MIC. I recall a few months ago I was able to access my home dir on the mic.
Do I need to run anything to get access to the home dir?
Thanks!
-John Tramm _______________________________________________ Admins mailing list [email protected] https://lists.jlse.anl.gov/mailman/listinfo/admins
participants (1)
Allen, Benjamin S.
